Author Topic: Just put my V8 in  (Read 13647 times)
Offline the_legend_1981
Just put my V8 in
« on: July 06, 2008, 07:35:06 pm »
It was a long weekend so i put a 350 in that I recently picked up. I put headers on and duals that end just before the rearend.  One of the pipes aims right at the rear axle so I was wondering if that would hurt anything for the time being...I plan on putting turndowns on but ran out of time.  It sounds great though, I'll put a video clip on when I get a few extra minutes.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Just put my V8 in
« Reply #1 on: July 06, 2008, 09:18:06 pm »
very cool, I change motors so much I can do them in just a couple hours  ;D
Offline 76 k10
« Reply #2 on: July 07, 2008, 01:44:34 am »
same here!!!! lol 45 mins was my best time!!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: July 10, 2008, 12:20:15 am »
You should work for Rick Hendricks or Joe Gibbs.
I used to put engines in old mustangs in a matter of hours--including the trans and all hookups. I swapped engines in my old stangs so often it was funny.
When I  installed my  383 stroker in my 79 I spent a couple of hours each evening after work through the course of several days. Had to take my time and do it right.
Then there was that time when I put a 400 cid w/ a 4spd muncie (attached) in my 70 firebird.  For some reason, after putting a new pressure plate, clutch, etc..on it  I went ahead and put the tranny on the engine, THEN tried to place the engine in the car.  I did it...had to take a 2x4 to help wedge that puppy in there and clear the headers.  Next time, I'll put the trans on after the engine is installed. Man that car with the 3.73 posi would FLY.  I wish i never sold that.
Offline 76 k10
« Reply #4 on: July 10, 2008, 02:22:32 am »
ok how did you drop the motor in with the headers on??? i have a 78 pontiac trans am with a 403 and i couldnt get it in with them?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #5 on: July 10, 2008, 10:19:09 am »
Quote
Lots of twisting and turning.  I had to jack up the front of the car quite a bit so the angle would be right.  I am hard-headed, and wasn't about to pull it back out to take the trans and headers off.  It eventually worked.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #6 on: July 10, 2008, 01:36:47 pm »
legend, when you get times we want to see pics  ;D
Sgt, I had a 70 firebird also, 400 4spd, but the bottom end of that 400 got real rattly so I put a 350 chevy in its place. Car was never the same again  :-\
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #7 on: July 10, 2008, 02:14:42 pm »
I have never driven a car as fast as that firebird.  Well, except for one when I did the NASCAR experience at Richmond Int'l Raceway.
That engine had recently been rebuilt and my gosh, that front end would lift up so much and burn rubber w/ the posi and fat tires in three gears. I got rid of it because I would have ended up in jail very shortly by driving that thing. I actually pulled that engine from a 76 Trans Am that was totalled.  She was sweet.
Offline 75 C20
« Reply #8 on: July 10, 2008, 08:57:28 pm »
I was always proud of my self for getting the engine outa my truck-i thought it was a chore until i put a new engine in a 95 chevy van. that made working on my truck like a piece of cake.  :D
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline 76 k10
« Reply #9 on: July 11, 2008, 01:24:06 pm »
i blow the bottom end outta my trans am so i put a sbc 283 that could hit 8500 rpms all day long and i have to say theres nothing like a pontiac big block lol im building a 550 hp 455 right now for it
Offline 76 k10
« Reply #10 on: July 11, 2008, 01:28:18 pm »
ya i no what you mean!!!! im 19 and i just got my drives license back! my trans am with a 403 would run low 13s then i would run the bottle and be in the low 12s pretty fast for running street tires
Offline SUX2BU99
« Reply #11 on: July 11, 2008, 03:02:51 pm »
^  :D I knew just by your posts that you had to be under 20. lol
Offline 76 k10
« Reply #12 on: July 11, 2008, 03:12:10 pm »
what you trying to say huh?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #13 on: July 11, 2008, 03:28:55 pm »
the 403 oldsmobile motor was kind of a turd, not that it couldnt be built  ;D Don't beat me up HAULIN IT lol  :D
« Last Edit: July 11, 2008, 03:35:18 pm by dumbucket1 »
« Reply #14 on: July 11, 2008, 04:19:36 pm »
Most factory Olds motors were less than impressive but you can do a lot with them. We made my buddy's 84 Hurst Olds into a 368 just to keep it all Olds power plant.
