Author Topic: reusing suspension hardware  (Read 15793 times)
Offline got2haul
« on: July 14, 2008, 02:49:48 pm »
I've read in several places that it's not a good idea to reuse u-bolts when making mods to your rear leaf spring suspension.  The argument makes sense to me.  But what about the u-bolt nuts?  Is it safe to use new u-bolts but reuse the old nuts?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Re: reusing suspension hardware
« Reply #1 on: July 14, 2008, 02:57:59 pm »
honestly, if you are going to the trouble of getting new bolts, why not get new nuts to go with them?
Offline HAULIN IT
« Reply #2 on: July 14, 2008, 04:23:37 pm »
I'm sure you will get varying opinions on this, here's my take.... I prefer OEM bolts, nuts, ect. I would rather re-use old (in good condition) hardware than cheap soft U-bolts from a spring shop, local auto parts store, ect. When I'm playing with leaf springs, I buy new bolts & nuts from the dealer (if what I'm doing is available) however I don't always put them on the first time together, in case I don't like how something is sitting. Once I'm pretty much happy I change them out one at a time, then re-tighten them all. Many, many vehicles have been apart & together too many times to count with old U-bolts, to each his own, Lorne
« Reply #3 on: July 14, 2008, 08:40:36 pm »
The spring shop around here sells way nicer U-bolts than the OEM ones. I always replace them unless they are fairly new.
Offline eventhorizon66
« Reply #4 on: July 15, 2008, 04:38:41 pm »
I'm with Haulin' It on this one, mainly because I don't know of a local place that sells decent hardware.  Home Depot, Lowes, and Ace are worthless when it comes to high strength hardware.
'85 C10 SWB 350 700R4 TKO600
« Reply #5 on: July 15, 2008, 04:46:32 pm »
Just be careful and make sure they are still good. A lot of times they will look ok and at a closer look you will notice that a portion of the threads is missing. Also many are stretched into yield and can never provide the same clamping force as when they are new and properly torqued. Haulinit makes a good point of mocking it up before actually torquing the bolts.
http://www.eatonsprings.com/ubolttorques.htm
« Reply #6 on: July 15, 2008, 10:45:13 pm »
100% new U bolts and hardware for final assembly. U bolts are stretched when they are torqued just like a regular bolt. I also agree that any spring shop around sells much better hardware than OEM ever was.
Offline HAULIN IT
« Reply #7 on: July 16, 2008, 02:10:51 pm »
Vile, That is exactly what I found virtually every time with the ones from the local spring shop (actually Two different shops) it seems as though the metal was softer & would pull slightly right where the nut was the time before. At a glance everything looks normal, a closer look or running the nut down revealed the U-bolts had stretched. I just finished my rear swap last night, took some pictures. I'll post them when I get a few moments. Lorne
Offline got2haul
« Reply #8 on: July 16, 2008, 02:48:46 pm »
Ok, Ok.  I bought new grade 8 nylock nuts to go with the new OEM u-bolts.  I am going to reuse the washers, though.  They're grade 8 and only a year and a half old.
Offline werewolfx13
« Reply #9 on: July 18, 2008, 12:06:59 am »
I work at Westlake/ACE hardware, any ACE store can order grade 8 U-bolts...Some Westlake stores can order grade 8 strength stainless bolts and u bolts..mine can't, unfortunately  :(
Chris
'83 Chevy c10 Silverado SWB
« Reply #10 on: July 22, 2008, 09:04:29 pm »
The local hardware store near me, and both lumber company's carry grade 8 hardware in stock up to 5/8".
Offline SUX2BU99
« Reply #11 on: August 05, 2008, 02:11:11 pm »
Does anybody know off-hand what the dimensions of the u-bolts and threads are?
« Reply #12 on: August 05, 2008, 02:15:57 pm »
It depends on your axle, and the # of leafs. Just match up your old ones if you've got em.
Offline SUX2BU99
« Reply #13 on: August 05, 2008, 02:57:28 pm »
Alrighty, I was just here at work and figured I'd look around on the 'net but I have them at home to measure them up.  I'll phone the dealer too to see if they got any OEM ones kicking around.
« Reply #14 on: August 06, 2008, 08:03:42 am »
Hight depends on your axle tube diameter, 1/2, 3/4, or 1 ton are different diameter axle tubes, also the number of leaves you have.
Width is known as ID, this also depends on your axle tube diameter. You will need to measure from inside to inside of the old U bolt.
As far as the size bolt, it is called wire size at the shops i have them made. That too you will need to meassure. Most spring shops can do this by make and model but also want to know what your meassurements are as well.
