Author Topic: painting engine  (Read 4192 times)
Offline the_legend_1981
painting engine
« on: July 14, 2008, 05:27:07 pm »
I was wondering if you guys have painted the engine and header while in the truck? I would have done it while it was out but i'm pressed for time because i have a 21 month old and 7 month old.  I think the engine paint might look decent if i degrease it but should i paint the headers first before i do that? I am going to change the intake and carb too from the current 2 barrel. What paint do you guys use?  Thanks for any help
Offline cracker0169
    • Myspace
Re: painting engine
« Reply #1 on: July 14, 2008, 05:51:05 pm »
For paint, I use the engine enamel from Duplicolor. You can pick it up at really any parts store, I even think wal mart carries it  ???
If doing it in the truck, I would get a couple cans of heavy duty degreaser and use a pressure washer.  To really get the headers painted right, you will prolly have to take them out. Which would be a good time to paint your engine without the headers in the way...
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
Offline 85shorty496
Re: painting engine
« Reply #2 on: July 15, 2008, 10:11:02 am »
Duplicolor will work well on the engine, i did mine black while still on the engine stand and it has weathered very well. the high heat paint they sell won't work on the headers at all. within days the "silver ceramic" was peeling off. i've heard that flat black BBQ paint works well but have never tried it myself.
« Last Edit: July 15, 2008, 10:41:34 am by Captkaos »
85 GMC shortbox
496/th400
12.31 @ 111 mph
1.70 60 ft
www.cardomain.com/ride/330832
" Old Chevys never die, they just go faster "
Re: painting engine
« Reply #3 on: July 15, 2008, 10:45:16 am »
You need to prep the block and get all the oil and grease off before you paint it.  Otherwise it won't stick.  I also recommend priming it before painting.
I painted my 454 Block with automotive paint.
Offline SUX2BU99
Re: painting engine
« Reply #4 on: July 15, 2008, 12:21:12 pm »
I followed Vile Zambonie's advice and painted my new heads with Rustoleum. Just their regular paint, not any hi-heat stuff. He said he's painted many engines with that and they've all held up well. I primered mine first with their primer. Well, I'm in Canada so I used Tremclad which is also a rust paint. No problems yet but it's still pretty fresh and not a whole lot of time yet on the new heads.
Re: painting engine
« Reply #5 on: July 15, 2008, 05:00:56 pm »
I had nearly 11 years on the paint on the 454 before it chipped at all. Prep is the key and keeping it free of oil and dirt until it's heated up and thoroughly dry. I have yet to find an actual engine paint that holds up better with the exception of boring machine grey.
