Author Topic: New Edelbrock - 2k idle, need help!  (Read 5065 times)
Offline Bowtie Bomber
  • Rolling American Iron
« on: July 17, 2008, 04:44:26 pm »
Hey guys I just bought a 600 cfm electric choke edelbrock and just put it on my '82 Silverado. For some reason it idles WAY to high, it idles at 2k RPM. I'm a Holley guy so this is a new ball park for me. Can anyone help me out? I need to get this done before sun down.
My truck is my flying fortress, the road is my sky, and Toyota's are the enemy bunkers that need a busting.
Re: New Edelbrock - 2k idle, need help!
« Reply #1 on: July 17, 2008, 04:50:21 pm »
Did you hook up the vacuum line for the brake booster in the back of the carb?
Offline TexasRed
« Reply #2 on: July 17, 2008, 05:16:11 pm »
Sounds like a vacuum leak.
« Reply #3 on: July 17, 2008, 06:17:07 pm »
After looking around the carb, I realized there was a plug hole for an optional power brake setup. So I looked in the box, found the plug for it and plugged it up. She runs AWESOME now! 800 RPM Idle, GREAT response and I get wayyy better fuel mileage. I really don't know why I was bothering with that Holley I had. I guess you where right Vile when you recommended an Edelbrock for a carb.
Thanks!
Offline TexasRed
« Reply #4 on: July 17, 2008, 07:25:14 pm »
What's wrong with a holley? I mean besides usually jetted too high (even for Houston which is lower than sea level), a power valve system which offers less driveability than a rod and spring enrichment system (even if you go to a dual stage), getting fuel all over the manifold when you want to change jets, gaskets below the fuel level (which can cause a leak if the gaskets don't seal), and the requirement of having the secondaries deliver fuel/air to keep the fuel in the secondary bowls fresh among other issues.
Glad you got it running good.
Offline lowriderbowtie
« Reply #5 on: July 17, 2008, 09:35:12 pm »
only problem ive had with edelbrock carbs is after time, thoes idle adjustment screws on the front back them selfs out from vibration.  im happy with my 1406 on my truck, great carbs
1976 3/4T Camper Special
350, LT headers, H pipe, Dynomax bullets, 4/3 drop
