Author Topic: Going backwards  (Read 4862 times)
Offline twisterme
Going backwards
« on: July 17, 2008, 06:02:51 pm »
Just completed installing a 250 (69 Camaro) in a 81 Chev C10 4x4 (used to be a 350 with HEI) .... age and hacking have the v-8 wiring in a mess. anybody know what wire connection is to positive side of the coil? Also need some help on what needs to go to the starter. I have only one large red wire to the junctin block on the firewall  and have two other large red wire connected together that I don't have a clue as to where it goes. Any help with a wiring diagram or pics would be greatly appreciated.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Going backwards
« Reply #1 on: July 17, 2008, 09:53:34 pm »
Ouch!  Good Luck!  I hate figuring out wires--it's a nightmare.
Re: Going backwards
« Reply #2 on: July 18, 2008, 08:49:36 am »
An 81 will have a HEI coil in Cap.  If you don't have one for the 250, and it is points, I would get one.
you have a positive from the battery to the starter and a hot wire from the starter to the junction on the firewall.
Re: Going backwards
« Reply #3 on: July 18, 2008, 10:10:43 am »
Do a search. There's quite a few posts with schematics
Offline twisterme
Almost there - V8 to 250 conversion C10 4x4
« Reply #4 on: July 21, 2008, 01:59:46 pm »
Well, I am almost there.... finally got a starter to work, (think it to be from a 348)... engine will consistently fire but then die. I have a wire from the "S" post on the starter to the positive side of the coil and a wire that is hot when the key is on to one side of a 9V ceramic resistor and a wire from the other side of the resistor to the positive side of the coil. Any ideas?
Re: Going backwards
« Reply #5 on: July 21, 2008, 02:40:53 pm »
Are you running an HEI or points?  What do you mean the starter is from a 348?  As in Cubic inches, as in NOT a Chevy starter?
Offline SUX2BU99
Re: Going backwards
« Reply #6 on: July 21, 2008, 03:18:42 pm »
^ I figure he means from a 348 W-head big block. Precursor to the 409. Came out in '58.
Offline twisterme
Re: Going backwards
« Reply #7 on: July 21, 2008, 03:47:57 pm »
running original points system..... starter is from an old "W" block, since posting noticed that the ru10 resistor I an using gets so hot it burned my finger
