Author Topic: dumb question  (Read 10639 times)
Offline 73c10Shorty
  • 73 Chevy Shortbed
dumb question
« on: July 19, 2008, 08:30:48 am »
So I'm trying to remove the instrument bezel and I am not sure how to remove the headlight knob. I assume you unscrew it but I don't want to break it.  ???
1973 C10 Shortbed, 350/350
Offline Toolmaster
Re: dumb question
« Reply #1 on: July 19, 2008, 09:55:02 am »
Look (feel) under the dash on the headlight switch, You will find a spring loaded button, push the button in and remove the knob.
Offline 73c10Shorty
  • 73 Chevy Shortbed
Re: dumb question
« Reply #2 on: July 19, 2008, 10:06:42 am »
Toolmaster, thanks for your reply. I don't see or feel the button you are referring to. Where is the button located on the switch? I can get my hand under the dash and move the switch around but I can't seem to find the button. Thanks again!
Offline eventhorizon66
Re: dumb question
« Reply #3 on: July 19, 2008, 11:04:57 am »
I've removed my bezel several times without removing the headlight switch knob.
'85 C10 SWB 350 700R4 TKO600
Offline 73c10Shorty
  • 73 Chevy Shortbed
Re: dumb question
« Reply #4 on: July 19, 2008, 11:35:18 am »
I don't see how that's possible. The headlight knob is in front of the bezel. ??
Offline bmaier
Re: dumb question
« Reply #5 on: July 19, 2008, 01:04:43 pm »
everytime i've had to take my bezel off i've never taken the headlight knob off either. all it takes is a little bit of wigglin around.
Re: dumb question
« Reply #6 on: July 19, 2008, 04:46:54 pm »
yes you just have to kind of wiggle it around but if you want to pull it out it's easy. Reaching behind the instrument cluster, depress the shaft retaining button and remove switch knob and rod.
Offline Prong
Re: dumb question
« Reply #7 on: July 19, 2008, 05:18:38 pm »
On the 73-76's, the bezel surrounds the switch to the point that the opening is just large enough for the rod to go through.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Re: dumb question
« Reply #8 on: July 19, 2008, 06:15:39 pm »
Well in that case, I was simply telling him to make him jealous.  :D
Offline Prong
Re: dumb question
« Reply #9 on: July 20, 2008, 12:32:18 am »
Yeah we get a bit spoiled on our newer stuff ;)
Offline 73c10Shorty
  • 73 Chevy Shortbed
Re: dumb question
« Reply #10 on: July 20, 2008, 10:23:09 am »
That's funny... I thought I was going crazy!  :o I never did find the button to release the rod. I ended up just supporting the bezel on a toolbox and letting it hang on the headlight switch rod. In the end it was a bust anyway since the fan blower switch that I ordered was the wrong one. I assume they sent me the switch for non-AC trucks. Oh well... Thanks again for the help guys!
Re: dumb question
« Reply #11 on: July 21, 2008, 01:03:29 pm »
The switch is on the column side of the switch body.
