Author Topic: Experience with converting to Rear Disc?  (Read 8219 times)
Offline Zeked
« on: July 19, 2008, 11:16:16 am »
I am thinking of upgrading the brakes on my 87 shortstep Has anyone put discs all around?  Is it worth going up a size on rotors?  Know of any exceptional kits?
Is it even worth it?
(besides ego gratification)
Thanks
Zeke
Often Wrong......Never in Doubt!
Offline cracker0169
    • Myspace
Re: Experience with converting to Rear Disc?
« Reply #1 on: July 19, 2008, 11:59:38 am »
http://www.stainlesssteelbrakes.com/
There are many more places out there to order complete kits. You could make your own brackets, get the rotors and calipers and make your own kit and save a few dollars! If you go too outrageous with brake sizes, you will have to upsize your wheels too though... point to ponder...
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
« Reply #2 on: July 19, 2008, 04:59:18 pm »
To do it right you need to bypass the combination valve and install new proportioning valves. I would use a quick take up master with low drag calipers. In my opinion it's not really worth it. If your drum brakes are in proper working order and your combination valve is good and your height sensing proportioning valve is working drum brakes will work better.
Why do you want to convert?
Offline lowriderbowtie
« Reply #3 on: July 20, 2008, 02:43:04 pm »
discs have more drag than drums
drums ftw
1976 3/4T Camper Special
350, LT headers, H pipe, Dynomax bullets, 4/3 drop
Offline static22
« Reply #4 on: July 20, 2008, 11:52:45 pm »
My opinion is you can probably take the money and spend it better on more worth while components for the truck. But that's just me.
« Reply #5 on: July 21, 2008, 10:35:09 am »
If it is a stock truck rolling on 15's, I would say it isn't worth it.  If you are building a show truck, yeah, but then  you would have bigger wheels.
Offline Zeked
« Reply #6 on: July 29, 2008, 10:15:12 pm »
thanks Guys....
It is a stock truck and I assumed that the discs had better stopping/fade characteristics
