Author Topic: REPLACEMENT BODY TO FRAME MOUNTS  (Read 8856 times)
Offline 85BURBAN
« on: July 20, 2008, 08:55:47 am »
does anyone know of any online companies that sell replacement body to frame mounts for the suburbans  i would prefer new ones if its possible before i hit the boneyards any help would be appreciated
Offline 80stepsideguy
Re: REPLACEMENT BODY TO FRAME MOUNTS
« Reply #1 on: July 20, 2008, 09:46:21 am »
Hey 85 burban,
where in RI are you located? I`m from RI myself and gonna head up there the end of august to be with family for 10 days. I think GM still sells them over the counter.
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #2 on: July 21, 2008, 01:05:15 pm »
Are you talking about the rubber body bushings or the actual mount that is riveted to the frame.
Offline 85BURBAN
« Reply #3 on: July 22, 2008, 05:14:55 pm »
im looking for the ones mounted/riveted to the frame
« Reply #4 on: August 01, 2008, 11:27:26 am »
Classic industries still sells them and there OEM replacements.
thanks
pat
« Reply #5 on: August 01, 2008, 11:52:42 am »
Have you checked with the dealership.  If Classic is selling OEM, that is where they are getting them from.
Offline chevyh20
« Reply #6 on: August 06, 2008, 10:44:19 pm »
i am looking for the same thing only for a blazer . does anyone know if suburban and blazer use the same body mount brackets?
« Reply #7 on: August 06, 2008, 10:58:06 pm »
What location?
Offline chevyh20
« Reply #8 on: August 07, 2008, 04:38:55 pm »
sorry for not mentioning the location . i need radiator support, front body mounts, and rear body mounts for 87 blazer. i was just wondering if suburban is the same as a blazer because i talked to someone that has good used suburban brackets , but not from a blazer . thanks
« Reply #9 on: August 07, 2008, 04:46:05 pm »
You need all of them? What happened to yours?
« Reply #10 on: August 07, 2008, 05:17:22 pm »
The radiator and the front cab are the same on every truck.  Burb, Blazer, pickup.  I don't think the rears on the Blazer and Burb are the same, but I haven't looked lately.
« Reply #11 on: August 08, 2008, 10:36:53 am »
I think the ones for the front cab ones on all 81-7 are the same for blazer/truck/suburban, if you have to i say if the body is already off, cut some steel plates, use a metal holesaw and cut holes for the mounts and weld on the plates, i had to do this to my 80 as the front 4 mounts on my truck were all shot and when ou hit a bump the cab bounced(typical new england weather ruined this truck) until i had to replace the entire and the frame.
thanks
pat
Look around in salvage yards i`m sure there has to be something for your rig
