Author Topic: shaved door kit help  (Read 7124 times)
Offline nucknoel89
  • Proud to be Canadian!
« on: July 21, 2008, 02:03:56 pm »
Okay, so I bought a shaved door kit off eBay and even though I can't do the bodywork for it I still want to install the solenoids and wiring myself.  Where's the best place to put the solenoid?  It appears that the latch pulls sideways and I wanted to have a straight pull but the glass is in the way.  There is also a little bit of hard tubing stuff which seems to be the right size to fit around the cable. Do I use that to redirect the pull somehow?  Also, I don't have power windows/locks so will I just have to drill a hole in the door for the wiring?
Re: shaved door kit help
« Reply #1 on: July 21, 2008, 02:38:14 pm »
There are several places to mount it.  When I had them I mounted mine in the open area of the door post and had it pull the same lever as the original handle.
With a pulley/wheel, you could mount it anywhere you wanted to.  There is a thread on this topic on the forum in progress by 2502 and Blitzer!
Offline nucknoel89
« Reply #2 on: July 21, 2008, 03:27:51 pm »
Okay thanks, I tried using the search function but it keeps giving me an error!
« Reply #3 on: July 21, 2008, 03:36:51 pm »
We are working on that, but it is under the body section
http://forum.73-87chevytrucks.com/smforum/index.php?topic=8052.0
« Reply #4 on: July 21, 2008, 03:53:08 pm »
The wiring and solenoids on mine are mounted behind the seat. Just remember to always leave a vent window unlocked in case the system fails or the batter goes dead or you'll lock yourself out. lol
Offline Bitzer!
  • Smiles per gallon
« Reply #5 on: July 22, 2008, 07:06:11 am »
Or to prevent lock-out, I've relocated my battery to the chassis under the passenger side. Just made a bracket and bolted it on, extend the wires and away you go never a flat battery. And install a 911 cable. Its a pull cable that pops the door from the "outside" wherever you locate it. Hope that makes sense!!
1979 GMC CrewCab  C20 1t
« Reply #6 on: July 22, 2008, 08:19:25 am »
You can also mount battery connects somewhere on the truck and get a boost from it.  Still need a way to get power, but at least you could get in.
