Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
Heater & A/C blower doesn't work on high speed
Topic: Heater & A/C blower doesn't work on high speed (Read 36863 times)
73c10Shorty
73 Chevy Shortbed
July 22, 2008, 12:34:24 pm »
So I'm still having problems with my A/C. I initially thought the switch was bad so I replaced it, but I still don't have high speed on the blower. Vile mentioned that it could be a relay. Does anybody have experience replacing this relay and possibly have a part # that I can reference?
1973 C10 Shortbed, 350/350
73c10Shorty
73 Chevy Shortbed
Re: Heater & A/C blower doesn't work on high speed
July 23, 2008, 12:06:07 am »
I found the relay and removed it. I'm going to replace it with a new one and see if that fixes the problem. After doing a little more research on this issue I'm confident that the relay will fix the issue. Yep... I should have listened to Vile's recommendation. In my defense... I had already ordered the switch.
Here's a link to where you can order a relay in case anyone else needs one.
http://www.classicparts.com/1973-77--Blower-Motor-Cut-Off-Relay/productinfo/68-341/
July 23, 2008, 04:49:42 am »
You can get the relay at any autoparts store.
73c10Shorty
73 Chevy Shortbed
July 23, 2008, 11:56:54 am »
You're right. I was able to get one from my local auto parts store. Unfortunately the new relay didn't solve the problem. I still don't have high speed on the blower. Any other ideas?
July 23, 2008, 12:03:09 pm »
Let's start from scratch here. I was under the impression you TESTED it. #1 check the fuse. All speeds except high speed work? I assume when you checked/replaced your switch that you checked the connections and wires? How are the connections at the relay? i posted a schematic for this in another thread.
73c10Shorty
73 Chevy Shortbed
July 26, 2008, 06:00:14 pm »
Yes, all speeds work except for high. All of the connections and wires look good at the switch and at the relay. Which fuse would I need to check? If it's not the fuse I think I'm going to have to take it to an electrical shop and let them figure it out. Thanks again for your help.
choptop
Extended cab fanatic
July 27, 2008, 09:36:24 pm »
What about the fan speed control resistor? (For lack of better words) non ac shown
choptop
July 27, 2008, 09:41:07 pm »
with a/c
July 27, 2008, 09:47:21 pm »
The resistor is bypassed in high speed. The wire is basically jumpered to the motor.
July 27, 2008, 09:52:04 pm »
My other post disappeared too. Make sure you check the B+ to the relay you replaced. On your truck there should be a fuse from the junction block
July 27, 2008, 10:25:24 pm »
I had to "fix" the post so everyone could reply.....
