Author Topic: carburetor issue  (Read 7610 times)
Offline 79c10454
carburetor issue
« on: July 26, 2008, 01:44:06 pm »
I have a 670 street avenger holley and original quad which carb is better as far as performance and durability. ??? ???
Offline TexasRed
Re: carburetor issue
« Reply #1 on: July 26, 2008, 02:35:50 pm »
The quadrajet is a great carb. You may need an adapter to get the holley on your manifold. If it's a stock or near stock engine, a stock q-jet is best, while you start moving away from stock, a holley's easier tuneability comes into play. Although if you dial in the quadrajet for the new engine, you get better fuel mileage and it'll be more on than the holley.
Offline eventhorizon66
« Reply #2 on: July 26, 2008, 02:49:39 pm »
If you are using a stock spreadbore manifold stick with the Q-jet; adapters kill power.
'85 C10 SWB 350 700R4 TKO600
Offline 79c10454
« Reply #3 on: July 27, 2008, 08:00:13 pm »
hey guys thnxs im not using the original intake, performer rpm
Offline TexasRed
« Reply #4 on: July 27, 2008, 08:22:58 pm »
Is it one of those manifolds with a dual patteren (ie, you could go spreadbore or squarebore). If it's a dual one, and you want to use a squarebore, there's a little plate thing you may need to get the combo sealed up.
Offline 79c10454
« Reply #5 on: August 01, 2008, 10:16:10 am »
Yes it is one of those with dual pattern bolt
Offline 79c10454
Carburetor issue bout electric choke
« Reply #6 on: August 01, 2008, 10:25:05 am »
That holley street avenger i have the electric choke is broken the blk plastic part. Is there anyway i can still use as it was manual choke ???
Offline camdenoilchange
Re: Carburetor issue bout electric choke
« Reply #7 on: August 01, 2008, 10:30:59 am »
check at summitracing.com, i believe they sell a manual choke conversion kit for it.
Offline 79c10454
« Reply #8 on: August 01, 2008, 10:32:28 am »
Hey thnxs bro cuz somebody said i just have take the electric choke stuff and it would be like manual choke i check to summit
Offline 79c10454
« Reply #10 on: August 01, 2008, 02:17:21 pm »
Hey cam i try the link but my part number carb doesnt show up
« Reply #11 on: August 02, 2008, 08:40:40 am »
you may have to research you carb more and go by the style. they may not list your exact model. You'll need to know what series carb you got, i.e. 4150 or whatever it is. I'm sorry I'm not familiar enough with holley to tell you off the top of my head. I'm sure a quick call to summit and they will be able to hook you up no problem.
Offline 79c10454
« Reply #12 on: August 05, 2008, 09:29:10 pm »
Hey thanks bro i check with summit and they hook me up ;D ;D
« Reply #13 on: August 06, 2008, 08:32:33 am »
not a problem. ;D
