Author Topic: Starter on 91 S-10  (Read 5055 times)
Offline 75 C20
Starter on 91 S-10
« on: January 30, 2007, 07:50:00 pm »
my starter on my 91 s10 with a 2.8 hasnt been engaging all the time when i go to fire it up. it will spin like crazy a lot on the 1st time of turning the key- then i let off and try it again and usally it engages and turns it over. so i was thinkin bout gittin a starter repair kit from  . its only like $17 so i hope that fixes it. any ideas/tips on this project- im hopeing to git it done on like a sat. will it be very hard to do with out a lift or is  the starter pretty easy to take off- and how hard is rebuilding one-i ve never had to rebuild one before so i dont know wut exactly im gittin into but it doesnt look to be that hard
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline roundedline
Re: Starter on 91 S-10
« Reply #1 on: January 31, 2007, 04:17:00 pm »
Doesn't engage as in grinding, or just free spinning?
What comes in this "kit"?
Replacement starters aren't all that expensive either.  I never found the occation to rebuild one short of swapping a nose.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #2 on: January 31, 2007, 05:29:00 pm »
Well after explaining to my class in GREAT detail all of the components within a starter, what they do, how they work, how to test every single component and overhaul them I am left with 2 good starters :lol  Not that it's that hard to do but why bother?
Anyway if your starter is engaging and not disengaging and it is overrunning then the starter solenoid is sticking and that's your problem. That's an ez repair. If the motor is turning your brush repair kit is a waste of $$
Offline 75 C20
« Reply #3 on: January 31, 2007, 07:23:00 pm »
i mean doesnt engage as in free spinning chris
this is the kit
its in the bottom corner- part number 36-1526
it says it has remanufactured starter drive, bushings, brushes, washers and snap ring
Edited by: 75 C20 at: 1/31/07 7:25 pm
Offline roundedline
« Reply #4 on: February 01, 2007, 10:30:00 am »
This kit won't fix your problem, you either need a new solenoid, or you need to pull the current one apart and find out what is causing it to stick.
Are you getting enough voltage to the starter?
Project Su
Jimmy 2WD Project
« Reply #5 on: February 02, 2007, 04:39:00 pm »
If the motor is turning but the drive pinion in't coming out, pop the solenoid off and see if you can actuate it with the plunger. If you can then replace the solenoid.
