Author Topic: Round to Square Front Clip  (Read 15111 times)
Offline Monzter
    • Monzter Kuztomz
« on: July 31, 2008, 02:39:04 am »
Well I just swapped my 73 Suburbans clip out for a front clip of a 86 Chevy truck. I thought that some people might like to what it takes to do this, everything I found on line did not show what it takes so I took pictures of my swap.
The unsuspecting Suburban.
The 73 front clip pulled off.
The plastic screen, weather strip & wiper mechanisms need to be removed now.
Now time to mark out where the cutting for new hood hinge holes & bolts need to be.
Here's where I had to add metal for the hood hinges, I added some support also, it seemed a little flimsy without it.
Test fitting the hinges.
With rubber.
Now it's time to drill holes for the wiper mechanisms, plastic screen & cowl. I forgot to take pictures of the drivers side wiper mechanism hole, it had to be enlarged to fit the longer mechanism.
After hoes drilled in the right spots I installed the cowl.
Next is to put the clip on.
Here you can see where I had to enlarge some of the holes to get the clip lined up.
Now the fenders are shimmed & bolted down.
Next is the hood. I drilled a hole in the firewall & used a new hood release cable to be able to open the hood.
The front body mounts had to be cut off & welded on in the right place along with cutting the frame for the bumper.
Drilling holes for bumper.
Ta Da! It's all on.
Next is to wire up the headlights & turn signals. I kept the wiring harness from the old clip top do this, the bulkhead connector is way different & wires will need to be spliced. I did no get pictures of this, it's not that hard to do though if you can do this clip swap.
Offline werewolfx13
Re: Round to Square Front Clip
« Reply #1 on: July 31, 2008, 03:27:16 am »
Good to see what all is involved. If I end up settling for a 73-80 cc srw 4x4, I'll end up doing the same thing.
Chris
'83 Chevy c10 Silverado SWB
Offline Bitzer!
  • Smiles per gallon
« Reply #2 on: July 31, 2008, 04:34:06 am »
Well impressed! Thought about doin mine but too much work-had ennuff on my hands! What colour is the ole girl goin?
1979 GMC CrewCab  C20 1t
« Reply #3 on: July 31, 2008, 10:21:46 am »
Looks good but I liked it better with older nose.
Offline the_legend_1981
« Reply #4 on: July 31, 2008, 11:13:36 am »
I agree with Zambonie
Offline Monzter
    • Monzter Kuztomz
« Reply #5 on: July 31, 2008, 12:23:33 pm »
I was planning on Silver with black tribal flames, I also have a air bag kit I was planning on putting on it too, now the air bag kit will be going on my 93 Dually.
« Last Edit: July 31, 2008, 12:26:01 pm by Captkaos »
Offline Monzter
    • Monzter Kuztomz
« Reply #6 on: July 31, 2008, 12:34:31 pm »
Yeah, I know that some people like the older front ends & some like the newer front ends so I expected that I would get people saying that they like the older clip better. I prefer the newer clip because it's smoother looking when you've got the billet grill & slopes down more giving you the feeling the truck is lower than it is. Besides my old front end was rotted out at the fender & radiator support from the battery, so this was one way of fixing it & getting the look I wanted.
Offline ca180
« Reply #7 on: July 31, 2008, 06:41:28 pm »
What wheels are those?
Torque thrusts?
Excellent write up
Offline Monzter
    • Monzter Kuztomz
« Reply #8 on: August 01, 2008, 12:45:17 am »
Torque thrusts?
Excellent write up
Polished 20" Coy's C5s
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #9 on: August 01, 2008, 03:40:19 pm »
good job, everytime I get a 81 up I immediately yank the nose off and put a round head light nose on it. Everyone has their own tastes.  ;D
Offline 80stepsideguy
« Reply #10 on: August 01, 2008, 04:07:16 pm »
Should be able to get money for the fenders and hood, they look to be in pretty good shape.
thanks
pat
« Last Edit: August 01, 2008, 06:06:58 pm by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
Offline Bitzer!
  • Smiles per gallon
« Reply #11 on: August 02, 2008, 06:41:21 am »
air-bag the burb!! cool m8
« Reply #12 on: August 02, 2008, 10:39:58 am »
Thanks for posting the info.  I have never had to move the core support mounts on any of them though.
Offline comp
  • 76-77-78
« Reply #13 on: August 03, 2008, 10:35:40 pm »
slick  ;D
Offline Monzter
    • Monzter Kuztomz
« Reply #14 on: August 04, 2008, 02:05:54 pm »
Really? Here's where the front two of my original rivet holes are from where the mount used to bee, it was about 1 1/4" to 1 1/2" from lining up. The original body mount bolt was also too short, I had to get one 4 1/2" if I remember right. The top bumper bolt ontop of the frame was in the right spot though.
