Author Topic: Rear Flip kit quest.  (Read 7526 times)
Offline 79c10454
« on: August 01, 2008, 10:31:01 am »
If i do 5inch drop flip kit do i have to c-notch the frame i was just wondering
Re: Rear Flip kit quest.
« Reply #1 on: August 01, 2008, 10:38:11 am »
No
Offline 79c10454
« Reply #2 on: August 01, 2008, 10:41:18 am »
Hey thnxs bro which brand qould reccomend since you have more time doing this then me
« Reply #3 on: August 01, 2008, 10:47:38 am »
Any flip kit manufacturer will work.  Last set I used was Western Chassis.  Does your truck had the HD springs?
« Reply #4 on: August 01, 2008, 01:39:16 pm »
I got mine from Summit
Offline 79c10454
« Reply #5 on: August 01, 2008, 02:12:02 pm »
yes it does have the heavy duty springs what do i change
« Reply #6 on: August 02, 2008, 10:44:32 am »
If it had standard springs, it will tend to bottom out on large bumps, so I would recommend one on those.  With HD springs that isn't as likely.
Offline three8six
« Reply #7 on: August 03, 2008, 09:46:31 pm »
On my truck when i flipped the rearend, I cut out the bumpstop brackets and put in some energy suspension bumpstops that were shorter and i gained back alot of the rearend travel I also had to put pinion shims in my leaf springs(2 degrees).
