Author Topic: drive shaft angle  (Read 6198 times)
Offline 06gsxrman1000
drive shaft angle
« on: August 02, 2008, 08:08:31 am »
i have a 87 gmc 1ton dually 4*4. the cross member that holds up the carrier bearring was rotted bad. i cant find a new one so i am gonna have to make one. my only concern is what is the proper angle of the driveshaft and how do u find the proper angle?
Three may keep a secret, if two of them are dead.
-ben franklin
Re: drive shaft angle
« Reply #1 on: August 02, 2008, 10:33:45 am »
Someone with a 2 piece would have to measure the factory angles for you between the two shafts to give you a good number. You can measure it with an angle finder.
Have you considered a one piece shaft? I had Camerota's build me this one to replace my 2 piece.
« Reply #2 on: August 02, 2008, 07:44:14 pm »
is that place in ct and how much $ did that set u back. that drive shaft is a piece of art
-ben franklin
« Reply #3 on: August 03, 2008, 09:05:43 am »
Yeah Camerota truck parts in Enfield. I did a ton of work on their sales reps 55 chevy so he hooked me up with a good deal but the guy in the driveshaft shop is cool. I'm sure he'd give you the best deal he can.
http://www.camerota.com/
