Author Topic: Won't gear down  (Read 3933 times)
Offline gbskunk2006
Won't gear down
« on: August 02, 2008, 11:19:02 am »
When I want to gear down (e.g. when going down a steep hill) and I move my column shift lever from DRIVE into 2nd my transmission doesn't gear down.  However, if I start off in 2nd gear (e.g. from a complete stop) it holds in 2nd until I move my shift lever to DRIVE.
I have a 4.3 litre V6, automatic), with approx 150,000 miles (250,000 km) shifts cleanly, and other than this little problem hasn't given me any problems.
I'm hoping a minor adjustment will take care of this?
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Re: Won't gear down
« Reply #1 on: August 02, 2008, 02:15:30 pm »
Is the linkage adjusted correctly? The manual valve should override and put you into 2nd when you select second.
Offline static22
Re: Won't gear down
« Reply #2 on: August 04, 2008, 12:30:20 am »
I have had a broken trans mount that has caused problems similiar to that as well.
