Author Topic: 1987 1ton  (Read 9379 times)
Offline 06gsxrman1000
1987 1ton
« on: August 05, 2008, 09:56:02 am »
i was wondering if anyone knows the stock size and length of the u bolts for the rear mount
Three may keep a secret, if two of them are dead.
-ben franklin
Re: 1987 1ton
« Reply #1 on: August 05, 2008, 09:58:32 am »
What rear mount are you referring to?
Re: 1987 1ton
« Reply #2 on: August 05, 2008, 10:13:42 am »
the bolts that hold the rearend to the springs
-ben franklin
Offline frogman68
Re: 1987 1ton
« Reply #3 on: August 05, 2008, 10:14:49 am »
My 76 uses 5/8 thread by 12 1/2 in square "U" Bolts not sure if they are the same..
Re: 1987 1ton
« Reply #4 on: August 05, 2008, 10:21:03 am »
do you know the spread(the distance from center to center)?
-ben franklin
Offline ccz145a
Re: 1987 1ton
« Reply #5 on: August 05, 2008, 10:24:45 am »
the length is determined by the spring leaf count.
06gsx,  this is a family-friendly site... might want to change your signature.
Offline frogman68
Re: 1987 1ton
« Reply #6 on: August 05, 2008, 10:35:19 am »
Mine are 2 1/2 almost 2 9/16 inches just measure the width of the spring..
Offline Cowboy_Customs
Re: 1987 1ton
« Reply #7 on: September 14, 2008, 11:18:04 am »
Just contact a spring shop n get em made. MOST places already know the answer to your question. I just got some made for my truck, all they needed to know were what the truck was, but i made sure I told em how long I wanted them, and the spring width. The actuall bolt diameter for what they made were same as factory. It was 20 bucks a piece, but worth every penny.
Dream Truck:
1991 GMC Crewcab Dually Western Hauler conversion 454TBI 4L80E 19.5's
http://community.webshots.com/user/Cowboy_Customs
Offline 86 chevy silverado
Re: 1987 1ton
« Reply #8 on: September 14, 2008, 11:51:00 am »
Leaf spring width (2 1/2"- 2 9/16") by your actual length needed for your spring pack and plates then add a couple inches for possible future add ons. You can get any size you want/need.
http://www.stengelbros.com/U-boltKitsSquare.htm
