Author Topic: Oil Pressure switch brass fitting damaged!  (Read 6191 times)
Offline 87r10shorty
« on: August 05, 2008, 11:23:37 pm »
1987 Silverado r10
V6
Shortbed
Oh much trouble am I in? When trying to change my oil pressure switch I snapped off the brass fitting in the block! 1. What is the name of that little brass piece? 2. How the heck can I get the snapped off piece outta my block?
« Last Edit: August 06, 2008, 05:05:31 am by VileZambonie »
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Oil Pressure switch brass fitting damaged!
« Reply #1 on: August 06, 2008, 04:23:31 am »
since brass is so soft I always lightly tapped a flathead screwdriver slighly larger than the hole and turned it out with no problems when this would happen to me.
« Reply #2 on: August 06, 2008, 05:06:27 am »
Use an extractor and unscrew it. You can buy a new adapter at your local autoparts store or hardware store.
« Reply #3 on: August 06, 2008, 08:06:19 am »
Its just a brass nipple, don't quote me but if I remeber correctly its 1/4 NPT.
Offline DnStClr
« Reply #4 on: August 06, 2008, 12:48:45 pm »
Here's what you're looking for R10Shorty- at Sears or Ace Hardware or auto parts stores. Tap it into the broken brass nipple and add some thread lube (WD-40) as you unscrew it.
Don
87 Chevy Silverado
Offline 87r10shorty
« Reply #5 on: August 06, 2008, 03:57:15 pm »
thank you everybody i managed to get it out of there
Offline DnStClr
« Reply #6 on: August 07, 2008, 01:03:41 am »
Awesome.
Don
87 Chevy Silverado
Offline HAULIN IT
« Reply #7 on: August 11, 2008, 06:20:04 pm »
The oil pressure sending unit? (back of the block behind the distributor) will be 1/8" NPT. Blazin, I'm thinking it's a male-female deal isn't it? Lorne
« Reply #8 on: August 11, 2008, 09:59:46 pm »
I stand corrected. I think I thought 1/8" but typed 1/4"
