Author Topic: Remanufactured AC units = Crap?  (Read 5650 times)
Offline Skunksmash
« on: August 06, 2008, 02:44:10 pm »
In the past i have heard people complain a lot about remanufactured units of pretty much all kinds. The problem i seem to be having is with an AcDelco remanufactured AC unit. On my 87 silverado 5.7 liter 2wd. I recently purchased the truck, and it came with all the components of the AC system. However, the belt that goes around the compressor was not on. I can only assume that the AC compressor has something wrong with it. What would you guys do in this situation? Should i just go buy an AC belt, put it on, ad then just hope it works? Or should i just replace the compressor? I am kinda unsure what to do here.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Remanufactured AC units = Crap?
« Reply #1 on: August 06, 2008, 02:46:43 pm »
I would find out what's wrong with it before I go throwing parts at it...
« Reply #2 on: August 06, 2008, 03:49:24 pm »
Check the clutch and see if it engages, just jump the wires going to it with power.  If it works, put a belt on it.
I am using reman parts on mine.
Offline Skunksmash
« Reply #3 on: August 06, 2008, 06:08:36 pm »
All the wires are still hooked up to it so i think all i would have to do is just turn the thing on with the switch inside the cab. Think it is a good idea to just go ahead and throw a belt on there? Just to see if just by chance it all still works, i mean.
« Reply #4 on: August 06, 2008, 08:33:21 pm »
what's the worst that could happen? You throw a belt? Try it out
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #5 on: August 06, 2008, 08:47:01 pm »
i have heard that some people take the belt off the compressor in the winter just to save fuel. I dunno if it does or not.
Offline Skunksmash
« Reply #6 on: August 07, 2008, 03:01:43 pm »
Thanks for the replies guys. I will just throw a belt on there, then report back on what happens.
