Author Topic: 12 bolt axles  (Read 5062 times)
Offline SBC384
12 bolt axles
« on: August 07, 2008, 10:29:16 pm »
hey was wondering if anyone had a how to or pics of an 12 axle installation ?  or tips
thanks
Re: 12 bolt axles
« Reply #1 on: August 07, 2008, 10:30:56 pm »
What do you mean? Just an entire rear axle swap?  ???
Offline SBC384
Re: 12 bolt axles
« Reply #2 on: August 07, 2008, 10:37:48 pm »
yes mine r bent have new ones here tomorrow w bearings n seals. had to turn gears to remove c clips just wondering if there was anything i might need to know to reinstall them
thanks
Re: 12 bolt axles
« Reply #3 on: August 07, 2008, 10:40:06 pm »
So you are only changing axle shafts then. you remove the cover, remove the pinion shaft bolt. Remove the pinion shaft, without turning the axles slide each one inward to remove the c-clips. then slide the axles out.
Offline SBC384
Re: 12 bolt axles
« Reply #4 on: August 07, 2008, 10:44:28 pm »
? about replacen seals n bearings u need tool correct? then they slide back n being careful not to mess up splines? ive got one out already. just read something about not turning axles which i did until i got one removed thats what im curious about
Re: 12 bolt axles
« Reply #5 on: August 07, 2008, 10:46:46 pm »
If you turn the axle with the pinion shaft out the spider gear will fall out. They're easy enough to put back in but just don't do it and you won't have to worry about it. As far as changing the bearings just use a slide hammer.
Offline SBC384
Re: 12 bolt axles
« Reply #6 on: August 07, 2008, 11:20:38 pm »
nothing fell out should b ok then ?
thanks will check back this week n thanks for ur help here and n susp !
