Author Topic: A/C Questions-  (Read 8165 times)
Offline DnStClr
A/C Questions-
« on: August 08, 2008, 11:46:20 am »
Air Conditioning isn't working. Also, two fan speeds, low speed and medium speed, are not working. Are these the resistors? I took the unit out and the metal tabs and springs look ok.
Sorry about the size of the pics. I'm trying to figure out how to resize them.
« Last Edit: August 08, 2008, 11:55:21 am by DnStClr »
Don
87 Chevy Silverado
Re: A/C Questions-
« Reply #1 on: August 08, 2008, 12:20:40 pm »
Yep that's the resistor assembly. So what is wrong with the A/C? Is the clutch not engaging? If not turn the a/c on and jump the low side switch with a paper clip. if the compressor engages you most likely have a low refrigerant charge.
Offline DnStClr
Re: A/C Questions-
« Reply #2 on: August 08, 2008, 02:01:22 pm »
Right- the clutch doesn't engage. I have the dash torn out right now tryin to make sure the vac lines arer hooked up and blower switch worked. All seemed ok. So I went to the resistors. Now to find that low pressure switch.. Is that it in the 1st pic next to the resistors?
Don
87 Chevy Silverado
Re: A/C Questions-
« Reply #3 on: August 08, 2008, 02:23:19 pm »
It's on the accumulator. That's the silver can in the engine compartment near the Evaporator case.
Offline DnStClr
Re: A/C Questions-
« Reply #4 on: August 09, 2008, 09:06:51 pm »
A/C on, jumping out the low side switch leads caused the rpms to increase. The clutch doesn't engage.
Don
87 Chevy Silverado
