Author Topic: Performance  (Read 5103 times)
Offline sgoody43
Performance
« on: August 08, 2008, 08:09:11 pm »
If I disconect the smog pump and the ac will I get some power.  I passed smog and so I dont need the pump but I am worried that it could go bad if it is not in use.  Do you guys think if I remove the belt and them install it again when I need to smog again that it won't have any problems.  I also want to install a throttle body spacer , a open ellement filter and a high flow cat.  Will I feel any thing.  How much power if I remove everything and add those mods.  Will my my edu act up without the smog pump
Offline Unofficial
Re: Performance
« Reply #1 on: August 08, 2008, 08:23:50 pm »
From what I've heard, throttle body spacers don't do much at all. Waste of money. They slap "AirRaid" on an over-sized gasket and sell it for $70.
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Re: Performance
« Reply #2 on: August 09, 2008, 04:25:03 pm »
Realistically you won't see any noticeable difference from what you talked about doing. You have money more well spent in other areas for noticeable improvements.
Offline Unofficial
Re: Performance
« Reply #3 on: August 09, 2008, 09:03:01 pm »
This is exactly what my dad told me. I wanted to try out a TB spacer, but my dad convinced me to do something more noticeable and beneficial. I spent about $300 to get all new true duals. Headers, mufflers, and an exhaust shop. I would put your money towards something else.
MSD ignition
Offline 82Shortbed
Re: Performance
« Reply #4 on: August 10, 2008, 02:31:37 am »
I have a TBI spacer on my '95 4.3,  It's made by trans-dapt and has a spiral design in the bores.  It doesn't whistle like most of them do, and maybe .2 seconds better on 0-60 and MAYBE a mile a gallon better economy.
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline sgoody43
Re: Performance
« Reply #5 on: August 11, 2008, 02:04:41 am »
hey thanks for the info.  I really want info from members that have expierience with a tb spacer.
