Author Topic: holley carb  (Read 4456 times)
Offline mikewb
holley carb
« on: August 09, 2008, 03:56:42 pm »
trying to put a holley 600 on my small block. aluminum intake. wont fit because of hitting where my transmission vaccum line hooks up on the back of the intake.  any other place i can pull vaccum for it soo i can fit it?
Re: holley carb
« Reply #1 on: August 09, 2008, 04:27:25 pm »
Yeah right off of the carburetor.
Offline camdenoilchange
Re: holley carb
« Reply #2 on: August 09, 2008, 05:30:03 pm »
Offline mikewb
Re: holley carb
« Reply #3 on: August 11, 2008, 12:39:48 pm »
on the back of the carburetor where my brakes hook or up front?
Offline eventhorizon66
Re: holley carb
« Reply #4 on: August 11, 2008, 07:31:11 pm »
Yes, there are two full vacuum ports; one in the front (3/16", I think), one in the back (3/8").  The 3/8" rear vacuum port would be for PCV, power brakes, TH350 vacuum modulator, etc.  If you can't use the port on the manifold, I guess you'll just have to use some tees.
'85 C10 SWB 350 700R4 TKO600
