Author Topic: back yard tranny flush  (Read 3765 times)
Offline csramsey640
« on: August 18, 2008, 07:33:00 pm »
I had an idea to get most of the fluid from my th400, just wonder if anyone tried it.  I was thinking about disconnecting the tranny lines, and installing some small steel to rubber lines.  1 would go in a clean bucket of dex3 the other in a dirty bucket.   If needed I have an inline fluid pump that I can use to help with.  Then drop the pan and do a filter. ???
Offline Dragon
Re: back yard tranny flush
« Reply #1 on: August 18, 2008, 11:27:59 pm »
If you have never done this before, you can easily make a big mess if you aren't careful....  I would suggest a good Siphoning Pump(Found at any Auto Parts/Hardware/Pet Supply Store) placed down the Trans Dipstick/Filler tube...
It's a 6ft Total Hose, but just check it will fit down the tube, or you may need a smalled Diameter Hose(Make sure it is Oil Resistant) found at any well stocked Hardware Store....
A Rinsed Out Plastic Gallon Milk Jug will make a decent fluid carrier, so long as the fluid is not hot....
« Last Edit: August 18, 2008, 11:29:49 pm by Dragon »
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
« Reply #2 on: August 19, 2008, 06:51:51 am »
I usually just drill with a magnet against the drill bit a hole in the torque converter. Then tap it for a pipe plug.
« Reply #3 on: August 19, 2008, 08:16:33 am »
Flushing is unecessary unless the system is contaminated. Periodic drain and fill with a filter change is all you need to do.
