Author Topic: Top 10  (Read 10459 times)
Offline DnStClr
Top 10
« on: August 18, 2008, 11:48:31 pm »
Here's a question that may have been asked before- what do you think are the top 10 performance enhancements for the 73-87 Chevy/Gmc trucks?
Don
87 Chevy Silverado
Re: Top 10
« Reply #1 on: August 19, 2008, 08:22:10 am »
Headers
Cam
Intake
Heads
ignition
exhaust
fuel system
shift kit
posi
lowering/lifting
improved cooling
removing pollution controls
Offline HAULIN IT
Re: Top 10
« Reply #2 on: August 19, 2008, 08:51:00 am »
Don, This could be a question with a rather broad range of answers depending on one's definition of "performance" & the real goals the owner has for his truck. Are we doing this for fun or our you trying to plan a build for your truck? Again depending on your own goals...tires & braking come to mind, may be of higher priority than some other things. Lorne
Offline bigkountry
Re: Top 10
« Reply #3 on: August 19, 2008, 09:17:21 am »
Go fast now, worry about stopping later!  ;D
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Top 10
« Reply #4 on: August 19, 2008, 09:22:52 am »
putting in a 383 Stroker (times 10)
Offline DnStClr
Re: Top 10
« Reply #5 on: August 19, 2008, 10:48:32 pm »
Ha- why did I know the stroker would be on Andy's list  :D
Not for my truck, Lorne. Just thought it would make a good topic. There's so many of you guys on here that are real gearheads- I wanted to see what comes to mind when you think "performance".
Don
87 Chevy Silverado
Offline team39763
Re: Top 10
« Reply #6 on: August 20, 2008, 12:36:17 am »
Here's how I tried to do my truck.
Headers
Air cleaner/filter
mufflers/exhaust
cooling system - efans/radiator/trans cooler
tune up - plugs/wires
wheels/tires
trans/shift kit
lowering
weight reduction
Exterior mods
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Top 10
« Reply #7 on: August 20, 2008, 12:51:56 am »
Quote
Don, you know me too well.  But then again, I am not exactly quiet when it comes to backing the good ole Stump Puller 383 Stroker.  ;D
Re: Top 10
« Reply #8 on: August 20, 2008, 09:57:36 am »
Are we talking 73-86 or 87 trucks?  Existing motor or we talking replacement?
Complete tune-up
Smog removal
Exhaust
Headers
cam/valvetrain
Intake
Carb
Heads
shift kit/perf clutch assm.
cooling (efan/radiator/trans)
If we are talking TBI same stuff applies, but you wont be changing carbs, and you cam selection is limited, but you could rebuild the TBI, or get a Holley 2" (or 454 TBI) and a Chip,
Offline DnStClr
Re: Top 10
« Reply #9 on: August 20, 2008, 11:38:59 pm »
As usual you make sense of a wobbly thought Chris. In fairness it should be 73-86. (Tho many of the changes can be done to the 87's too.) Existing engine. Anything else is fair game for an upgrade. Actually, I thought new final drive ratio might score kind of high on the list.
Don
87 Chevy Silverado
Offline HAULIN IT
Re: Top 10
« Reply #10 on: August 21, 2008, 08:58:21 am »
It would/should!
Offline Bowtie4004x4
Re: Top 10
« Reply #11 on: August 27, 2008, 01:52:25 am »
 There are a whole lotta variables to that question, but for seat of the pants performance you can't beat a set of gears. Jump from 3:07 to 3:42 or 4:10 and see how your neck feels  :o
  Horrible gas mileage but you said performance hehe.
 After gears I agree with your basic setup outlined by some others on here.
I'm spending my children's inheritance on my Trucks.
'78 3/4 fleetside 4x4 4oo/400 3:73gears (frame off rebuild)
'80 3/4 fleetside 4x4 305/400 4:10gears (if I took the body off the frame it would fall totally apart...lol )
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Top 10
« Reply #12 on: August 27, 2008, 12:40:49 pm »
Quote
Not necessarily a performance upgrade. Performance could mean "top end".  Suppose you want to go over 100 mph?  hmmm?  That engine would be nearly redlining.  A 2:80 to 3:08 would'nt even be necessarily breaking a sweat.  Now a 383 with a 3:08, lotsa torque down low and plenty of upper end for interstates. Yeah, that's the ticket. By the way, that's whay I have in my 79..
Re: Top 10
« Reply #13 on: August 27, 2008, 03:49:55 pm »
   That's why I started my post with this statement. For myself performance means neck snapping, tire ripping torque. Easiest and most cost effective way to obtain that is with a set of gears IMO. Going fast scares me, must be why I have a 4x4 and play slowly in the mud  ;)
