Author Topic: driveshafts?  (Read 3369 times)
Offline 2502
driveshafts?
« on: August 20, 2008, 11:54:31 am »
converting the olds conversion back to chevy... the olds driveshaft is a two piece, the chevy isn't. i'm swapping the chevy parts over, now does the rear end have to go with the driveshafts or will it mate up with  what's in my truck already? swapping from an 80 silverado to a 79 silverado that had the olds engine and tranny in it.
Re: driveshafts?
« Reply #1 on: August 20, 2008, 12:07:18 pm »
Do you mean will the U-joint fit in the yoke? You need to take a measurement because there is more than one yoke size. If the shaft length is correct and the yokes are mismatched you can purchase a conversion joint.
Offline 2502
Re: driveshafts?
« Reply #2 on: August 20, 2008, 01:04:45 pm »
yeah i was just going to take the driveshaft from the chevy since it's theone that was originally bolted to the tranny to begin with. just didn't know if i need to swap out my rear for any reason...
