Author Topic: Are '87 and '88 TBI identical?  (Read 10839 times)
Offline Unofficial
« on: August 20, 2008, 12:14:46 pm »
I know that '88 is when the body style changed, but how different were the motors? I was looking into a Cold Air kit from K&N, and they have a kit for an '88 C1500, but not an '87 R10, which is what I have. I recently put in a 350 that was from an '88, but I used my TBI and intake from the original 305. So, are the throttle bodies the same? Would I be able to install the kit, or are the 88 models different under the hood?
Here's one I was looking at: http://store.summitracing.com/partdetail.asp?part=KNN%2D57%2D3026&view=32&N=700+
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Re: Are '87 and '88 TBI identical?
« Reply #1 on: August 20, 2008, 12:19:07 pm »
The throttle bodies are the same but the air cleaners were different. That one you are looking at is made to go where the factory one is.
Offline Unofficial
« Reply #2 on: August 20, 2008, 12:25:51 pm »
So there was an air cleaner on the inside fender in the 88 model? Hmm, I was looking forward to installing a kit.
MSD ignition
« Reply #3 on: August 20, 2008, 02:42:01 pm »
87-91 motors were identical, in fact up to 93 was the same basic engine
The TBI is the same from 2.8L, 4.3L, 5.0 and 5.7 and 7.4L minus the 454SS.
The truck should already have a fresh air kit on it that goes to the core support, so you aren't going to be gaining anything with that kit.  Just put a good filter on it.
Offline eventhorizon66
« Reply #4 on: August 20, 2008, 05:12:05 pm »
You could always add another snorkel to your current air cleaner and use both air intake holes in the core support, like Haulin It did.  I am working on a project like this, using two '92 TBI truck air cleaners.  Personally, I think a tube style intake would look odd and out of place in one of our trucks.
'85 C10 SWB 350 700R4 TKO600
Offline KoolerSL2
  • Chevy / Ford: A house Divided
« Reply #5 on: August 21, 2008, 09:35:26 am »
or you could do something like i have done.
total cost was around $200 for everything.
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
Offline Unofficial
« Reply #6 on: August 21, 2008, 01:44:17 pm »
Wow, I really like what you did Kooler. Would you mind explaining how you did that? Where did you get that piece the goes on the carb? What about the tubes, did you just buy tubing, or were those made for that? Did you notice a big difference when you put that on?
MSD ignition
Offline KoolerSL2
« Reply #7 on: August 21, 2008, 05:26:58 pm »
thanks for the complment.
the intake hat is made by Spectre.
its a Dual 4" inlet.
the couplers are from lowes and are 4" sewer pipe couplers.
the tubing is a 4" Exhaust elbow from a big truck shop that i cut in half.
the filters are from autozone and are universal.
price break down.
Intake Hat: 78.99 shipped from summit
Couplers: 12.00 from Lowes
Exhaust Pipe: 40.00 from I'ntl truck dealer
Filters: 55.00 from autozone
and as for a performance kick, it helps a lot better right now at speed. im working on kinda boxing the filters from engine heat.
as now at idle its just like a open element filter, but at speed when cool air is hitting the filters it responds soo much better.
Offline Unofficial
« Reply #8 on: August 21, 2008, 10:27:26 pm »
Not that I'm trying to copy you, but may I ask exactly where you got those tubes? Do you mean it's an exhaust pipe from those big huge International trucks? Is there anything else I could use?
MSD ignition
Offline KoolerSL2
« Reply #9 on: August 21, 2008, 11:28:33 pm »
pretty much its exhaust pipe.
you could use some 4" PVC pipe.
Offline Unofficial
« Reply #10 on: August 22, 2008, 09:16:50 am »
I heard that PVC pipe is bad for your engine when you use it like that. Is there any truth to that?
MSD ignition
Offline KoolerSL2
« Reply #11 on: August 27, 2008, 02:11:32 pm »
ive used PVC pipe without issues.
i just use the thick gray colored stuff.
its made to withstand extreme temps and such.
it is a bit heavy but wont heat soak like metal pipe will.
Offline Redneckchevy
    • Photo Bucket
« Reply #12 on: August 27, 2008, 03:19:44 pm »
Or you could do what i did.....Put a Hood scoop on your truck...And then Put a Hood scoop plate on your carb so all that cold air is shoved in....K&N Even makes hood scoop filters..When it rains...Put the plug in the scoop..:P
Offline Unofficial
« Reply #13 on: August 27, 2008, 05:32:48 pm »
That's not my preference, and it would probably cost more also.
MSD ignition
