Author Topic: 4 link?  (Read 16924 times)
Offline Chevalade
4 link?
« on: August 20, 2008, 09:55:13 pm »
Dos anyone make a good 4 link kit for our trucks....I have looked, but havn't found much.....lots of air ride stuff...but no 4 links.
Just wanting to run a 4 link so I can run a bit wider meats for traction.
Any sites or direction would be appreciated. Thanks.
Re: 4 link?
« Reply #1 on: August 21, 2008, 11:25:12 am »
If you are talking bolt in, No.
Offline Chevalade
Re: 4 link?
« Reply #2 on: August 21, 2008, 09:25:45 pm »
Hmmm......ok. That was easy.
Offline cubicdollars
Re: 4 link?
« Reply #3 on: August 24, 2008, 07:40:48 pm »
I use a chris alston 4 link for mine, I did use the stock frame rails but there is alot of welding involved, here is a link
http://community.webshots.com/user/Thorenson?vhost=community
let me know if this helps
Offline Chevalade
Re: 4 link?
« Reply #4 on: August 25, 2008, 07:21:16 pm »
Not really....it took me to the webshots homepage.
Re: 4 link?
« Reply #5 on: August 25, 2008, 07:49:29 pm »
Click the big "go to webshots" button after it opens.
Re: 4 link?
« Reply #6 on: August 25, 2008, 09:19:29 pm »
I thought I had more 4 link photo's im my webshots page, here is a pdf file from chris alston  http://www.cachassisworks.com/Stories/HowCAC-009_WEB.pdf
Offline Chevalade
Re: 4 link?
« Reply #7 on: August 25, 2008, 10:24:55 pm »
Excellent article...thanks a bunch.
Re: 4 link?
« Reply #8 on: August 26, 2008, 11:59:50 am »
That's the article I used when I install mine in 1997  ;D
Offline camdenoilchange
Re: 4 link?
« Reply #9 on: September 06, 2008, 08:04:29 am »
here is a bolt on 4 link for 73-87 chevy's.
http://www.kplinks.com/product.php?productid=150&cat=72&page=1
Offline Chevalade
Re: 4 link?
« Reply #10 on: September 06, 2008, 09:44:50 am »
Good to know there is one avail.
Offline Chevalade
Re: 4 link?
« Reply #11 on: September 15, 2008, 10:04:38 pm »
Found this in my searches....not sure if it will be of use to anyone else....but the price is close to the one above, but this setup includes the panhard bar.
http://www.theslamstore.com/product_p/bo4l-06.htm
Re: 4 link?
« Reply #12 on: September 16, 2008, 05:03:26 am »
Quote
Already been posted
Offline SCOTI
Re: 4 link?
« Reply #13 on: September 23, 2008, 09:38:09 pm »
How much tire are we talkin' about? The problem w/the bolt-in 4-link style kits is they won't allow for much more tire than the leafs you'd be swapping out.
In order to gain more clearance, you'll need to go to the trailing arm style rear set-up (CPP did a 73-87 kit for this) or go 4-link inside the framerails. The inside the rails set-up allows for a bunch more tire but decreases the trucks stability because the suspensions leverage is closer to the C/L of the vehicle.
Offline static22
Re: 4 link?
« Reply #14 on: September 23, 2008, 10:32:57 pm »
If your buying new wheels you can play with the offsets as well to maximize the room that is available with the stock configuration.
