Author Topic: coolant coming out the exuast  (Read 5501 times)
Offline chevyboy1983
« on: August 22, 2008, 11:35:25 pm »
On my 1983 Chevy 1/2 4x4 I've noticed that there has been cooland coming out the Y between the Headers and the tail pipe cause the gaskets are gone.  Could it be the head gasket?  I dint have any water in the oil it still runs good.  But I'm losing coolant.  Wondering if anyone else had this prob.
Offline 80stepsideguy
Re: coolant coming out the exuast
« Reply #1 on: August 22, 2008, 11:38:46 pm »
Definately sounds like a head gasket gone bad. check the oil and see if it looks watery and smell it if you smell antifreeze its definately a head gasket.
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #2 on: August 22, 2008, 11:47:59 pm »
thanks
pat
there is no water in the oil.  Somebody told me to tkae off the valve cover and check and see if there is coolant in the valve covers that the head is bad is that true?
Offline 86 chevy silverado
« Reply #3 on: August 23, 2008, 07:00:18 am »
Are you positive you have coolant not water coming out your exhaust?
If so pull and inspect your plugs for signs of coolant. Pressure test your coolant system, look for pressure drop. Inspect for obvious leaks first if pressure drop is noted. Crank over the motor with plugs out and see if coolant comes out of problem cylinder(s) if there is one.
A cylinder leak down test is another way of looking for a bad head gasket, but not too many people have a leak down tester in their garage. Procedure is similar, Pressurize the cylinder observe pressure drop, if there is check for pressure in coolant sytem or bubbles in radiator.
« Reply #4 on: August 23, 2008, 09:47:14 am »
If it is burning coolant you will see white smoke in the exhaust. If you are just seeing water that is normal. For every gallon of gas you burn you produce nearly a gallon of water in the exhaust. Seeing water in the exhaust is ok.
Offline bigkountry
« Reply #5 on: August 23, 2008, 11:24:51 am »
What Vile said, ther will be a sweet smell to the exhaust as well in most cases.
Offline TexasRed
« Reply #6 on: August 23, 2008, 07:55:48 pm »
In his original post he said he was "losing coolant". So is your coolant level actually dropping?
« Reply #7 on: August 24, 2008, 07:51:03 am »
He needs to pressure test the cooling system to find the source of his leak.
