Author Topic: 1977 Dually Lowering Question  (Read 8515 times)
Offline BigStella
« on: August 23, 2008, 09:07:41 am »
I have a 1977 crewcab dually, that I want to lower.  I have two questions.  As far as flip kits and everything I find online they are all for 1/2 ton trucks, where do you suggest I find stuff for my 1 ton?
What is the most economical way to lower it front and rear?
I have 16" alcoa wheels, would like it to sit closer to them, I DO NOT want to have to notch the frame.  What is the most I could go and what would you recommend, flip kit/spindle? or ???
Thanks,
Timm
www.projectbigstella.com
Re: 1977 Dually Lowering Question
« Reply #1 on: August 23, 2008, 09:59:43 am »
Have you considered bagging it?
Offline BigStella
« Reply #2 on: August 23, 2008, 05:40:49 pm »
I am just looking for the most economical route.  I would think that bagging it would be much, much more expensive...
What do you think the costs difference would be?
Offline cubicdollars
« Reply #3 on: August 24, 2008, 07:36:41 pm »
Check out my build that I completed this spring it's lowered  by Bell Tech spindles and I am planning on removing a bunch of rear leaf spprings and to maintain my load rating by adding air lift airbags for the rear suspension.
Here is the link to the build
http://community.webshots.com/user/Thorenson?vhost=community
« Reply #4 on: August 24, 2008, 11:42:53 pm »
There is a post dicussing this exact topic.  Belltech makes 1T stuff.
