Author Topic: summit brand mufflers??  (Read 31181 times)
Offline bigblue09
« on: September 01, 2008, 05:15:26 pm »
what do you guys think about the summit brand mufflers? how do they sound in regards to flowmasters or magnaflow??
'87 Silverado EFI 305
Offline HAULIN IT
Re: summit brand mufflers??
« Reply #1 on: September 01, 2008, 09:18:27 pm »
I put a pair of the (2 1/4") fully welded ones on my beater truck. Pretty much stock 350, with cast iron manifolds... They sound odd to me, a little rumble at idle, as you give it the gas (especially going up hills) it makes this resonant, gargleling sound in the mufflers, it has tailpipes turning out behind the wheel, so really I wouldn't have expected this echoing noise. Maybe on another engine or bigger ones are different, but would not be my pick. Lorne
Offline KoolerSL2
  • Chevy / Ford: A house Divided
« Reply #2 on: September 02, 2008, 10:39:10 pm »
i have a set on my truck in 3 inch.
do sound a bit different.
heres the link to my clip.
http://www.sixthsphere.com/storage2/images/hkh159sfi9aceibwo7zz.wmv
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
Offline bigblue09
« Reply #3 on: September 02, 2008, 11:33:47 pm »
the link is not working  :(
Offline KoolerSL2
« Reply #4 on: September 03, 2008, 12:08:16 am »
try it again. or right click save as.
Offline bigblue09
« Reply #5 on: September 03, 2008, 10:07:40 am »
yea they do sound a little different but they dont sound bad at all.
Offline Blue 82
« Reply #6 on: September 03, 2008, 02:56:30 pm »
I have a pair of the 2 1/4" on my truck
a bit too loud for my taste
even with an 'H' pipe
They did have an odd sound as others have noted
That went away with the 'H' pipe
They are well built
and won't expand or split
Offline team39763
« Reply #7 on: September 04, 2008, 09:24:12 am »
I know you didn't ask about other mufflers, but I installed a Thrush welded(chambered) muffler on our dually and it sounds exactly like a flowmaster.  It's around the same price as the summit welded mufflers and looks similar too.
Offline ccz145a
« Reply #8 on: September 04, 2008, 02:51:04 pm »
try looking the x pipe kit that Chris sells on this site. Can't beat the price unless you cut and bend pipe yourself.
« Reply #9 on: September 04, 2008, 07:40:31 pm »
You would be better off getting a system from Summit, it is a dynomax setup, and they are cheaper.
As CCZ144A said, we have x-pipe kits, but they are for long tube headers.  They will work with manifolds, but you have to have downpipes made.
Offline Skunksmash
« Reply #10 on: September 12, 2008, 02:13:18 am »
Is 2.5" the size you recommend? I see it is the size you sell but a lot of guys that like to go 3" but i never knew if that was the right size for a street truck that wont be making crazy power... would there be anything to gain from using 3" over 2.5"?
Offline Dragon
« Reply #11 on: September 12, 2008, 04:14:04 am »
For an L05/350, 2.5" True-Dual would be perfect for a Stock to Mildly Built Engine, anything bigger would be "Over Kill" and a Waste of money(You probably would see a Performance decress, since your engine would be struggling to exhale that much)...  The Only time I have ever seen a 3" system benefical to a Stock to Mildly Built Engine, was when it was a Single Exhaust System(Entire Setup from the headers/manifolds to the muffler and out), or Even a Single to Dual Outlets(From the Headers/Manifolds, to the Muffler, and Split Out)..  Those systems were usually put on 88-98 C/K trucks, and the Third & Early Fourth GEN F-bodies....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
« Reply #12 on: September 12, 2008, 12:07:56 pm »
Personally for any streetable 350 2.5 is going to be fine.  For a 454, 2.5 should be fine also.
Offline Skunksmash
« Reply #13 on: September 13, 2008, 08:16:42 pm »
Hmm, how much HP/Torque would you say is ok to use with a 2.5" setup? I mean, what's the max before you would go with 3"? I ask because i do have some other mods in mind and i would not want to restrict the engine to much.
« Reply #14 on: September 13, 2008, 11:49:32 pm »
Any Big Block I ever built needed 3" exhaust to breath. If you are going over 450HP 3" will be a good idea
