Author Topic: how to modify AC bracket for use with headers  (Read 20319 times)
Offline loudnlow87
« on: September 01, 2008, 05:20:04 pm »
how did you guys with AC modify the bracket when you got headers to make it work?
stock really sucks
Offline eventhorizon66
Re: how to modify AC bracket for use with headers
« Reply #1 on: September 01, 2008, 06:28:12 pm »
Here's how I had to modify mine.
« Last Edit: April 16, 2009, 02:33:30 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline loudnlow87
« Reply #2 on: September 01, 2008, 06:55:57 pm »
oh wow thats a great pic thanks so much!
stock really sucks
Offline caprice86
« Reply #3 on: June 13, 2012, 09:08:00 am »
did u use spacers if so what size and from where thanks
Offline Fairlane514
« Reply #4 on: June 13, 2012, 07:09:48 pm »
I made the same cut on my bracket, but then I welded a piece from the bracket so I could bolt it to the third hole on the header flange. I actually used the round rod with the holes on each end from the smog pump. I bolted it to the third hole on the header and tacked it where it hit the A/C bracket, removed it and finished the weld.
I used the original studs from the exhaust manifold with some spacers.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #5 on: June 19, 2012, 11:33:42 am »
Here are somepics I posted on photobucket of when I did mine. The bracket is from Hooker and it fits the rear end of the A6 compressor. I cut a piece of 1/2 gavanized water pipe I had to a length that would make up the thicknees of the factory exhaust manifold minus the thickness of the headerflange. I painted it black and used a longer bolt. Simple
http://s971.photobucket.com/albums/ae191/bobcooter/AC%20brackets%20for%20headers/
Offline dan.mccarthy.7731
« Reply #6 on: December 16, 2014, 07:06:11 am »
No different bracket no a/c will send pic but the power steering pump is tight.thanks
« Reply #7 on: December 16, 2014, 08:11:55 pm »
