Author Topic: 15x12 wheels  (Read 21068 times)
Offline gerardo0367
  • hi all
15x12 wheels
« on: September 02, 2008, 12:38:55 am »
I found some 15x12 slotted mags with a 4.5 in backspacing has anyone ever installed these on a fleetside truck i figure i might only need to mini tub the bed not sure on the tire size yet
All Man wheres my wallet and my keys I wont try that again
Re: 15x12 wheels
« Reply #1 on: September 02, 2008, 08:11:37 am »
I think you may have to narrow your rear axle or they will stick out further than the body
Offline Chevalade
Re: 15x12 wheels
« Reply #2 on: September 02, 2008, 11:58:05 am »
Now would a 12" with a 5 or 5.5" backspacing fit I wonder?
Re: 15x12 wheels
« Reply #3 on: September 02, 2008, 12:00:01 pm »
It won't tuck at 5".  I think you need about 6".  Best way to tell is to measure it.
Offline Chevalade
Re: 15x12 wheels
« Reply #4 on: September 02, 2008, 12:02:07 pm »
So then a 10" wide rim would need 5" to tuck?
Re: 15x12 wheels
« Reply #5 on: September 02, 2008, 12:35:42 pm »
Yes.  I had 8.5" impalas on mine with 5" BS and you could probably get another 2" outward on mine.
I would still measure just to be certain.  If the bed got tweaked or the frame got tweaked it can throw it off a little.
Offline Chevalade
Re: 15x12 wheels
« Reply #6 on: September 02, 2008, 12:47:05 pm »
Whats the max bs we can run on the back before running into clearance probs?
Re: 15x12 wheels
« Reply #7 on: September 02, 2008, 02:36:27 pm »
I think I have 4.5" backspacing on my 10" wide slots and they are even with the body. So to fit I think 4" is the most you could go if you plan on really slamming it in the rear.
Re: 15x12 wheels
« Reply #8 on: September 02, 2008, 04:47:37 pm »
Most guys running larger rims (like 20-22's) are running a 9" wide rim with 5 or 5.5" backspacing.  I know you can run a 10 on there and tuck, but I don't know about a 12.  Like I said, measuring would be the best option.
Offline GVazquez
Re: 15x12 wheels
« Reply #9 on: September 02, 2008, 10:27:07 pm »
I know a guy that runs 15x12 with a 7.5 backspacing , BUT he had to widen the wheel wells on th bed 1"
Offline got2haul
Re: 15x12 wheels
« Reply #10 on: September 03, 2008, 12:55:44 pm »
Mine's a stepside, so there may be some difference but I run 10-inch wide wheels with 5-inches backspacing.  Tires are 295/50/16.  The truck is lowered 4-inches in the rear.  The tire is about 12-1/4 inches wide at it's widest point (section width) on the 10-inch rim.  There is about 1-1/8 inch clearance between the sidewall of the tire and the bed side, and about 3/8-inch clearance from the sidewall to the inner fender lip (the fender lip is not rolled).  Another 1/2-inch to 3/4-inch clearance at the fender lip could be gained by rolling the inner lip, allowing an 11-inch rim to be used with a slightly wider tire, provided I were to add another 1/2-inch backspacing.
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Offline gerardo0367
  • hi all
Re: 15x12 wheels
« Reply #11 on: September 03, 2008, 08:24:31 pm »
Not slamming it i want the top of the tire visible but will lower it some  and yes it will have a rack to it    ;D
