Author Topic: How do you raise the bumpers to match a body lift?  (Read 23824 times)
Offline Mike Phillips
« on: September 03, 2008, 03:49:59 pm »
If you install a 3" body lift kit your bumpers will be positioned 3" below the body.
If you want to keep a clean look do you modify how your bumpers are mounted to the frame?
California restricts how high you can raise the frame and the body so I'm looking at a combination of both for the new 35" tires.
Offline Unofficial
Re: How do you raise the bumpers to match a body lift?
« Reply #1 on: September 03, 2008, 03:52:26 pm »
I'm not talking from experience, but there's quite a few lifted trucks in Wisconsin. :D I think it looks tacky when people do the lift and have a big gap between the body and bumper. I live across the street from someone who has his bumper fabricated to close the gap, I'll get some info for you.
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
« Reply #2 on: September 03, 2008, 05:53:39 pm »
After a little research the only option appears to be to make the necessary customizations yourself.  As such, the plan is this summer to go to my hometown for a class reunion and while I'm there let my best friend and drag boat buddy weld on a 12" H-Beam bumper to the front and rear this will solve the problem and give me a place to mount a vice.
This is my best friends truck... it's street legal in Oregon...
« Last Edit: September 04, 2008, 03:49:24 am by Mike Phillips »
« Reply #3 on: September 03, 2008, 06:18:07 pm »
You know Ford's F350 from the factory will fit 35"s so I don't see why a 4" or 6" suspension lift would be a problem.
« Reply #4 on: September 03, 2008, 06:53:37 pm »
These older Chevy fender designs are kind of squared up and that causes a clearance problem towards the corners.  I don't remember having as much of a problem with my 1971 3/4 ton 4x4
Here's a shot of of the clearance with the tires pointed straight ahead... turning the front wheels rams the tires into the lip of the fender.
Also, there's going to be a little more weight on the front end as I'm swapping out the small block and installing a big block.
Offline bmaier
« Reply #5 on: September 03, 2008, 07:18:11 pm »
just get a 6" lift or a 4" lift with slight modification to the front inner fenders. i have a 4" lift and i just trimmed the inside of my fenders and problem solved. lifts aren't that expensive anyways.
Offline JRConnieK10
« Reply #6 on: September 03, 2008, 11:07:42 pm »
I had the same problem so I changed the front bumper and welded a piece of angle iron to the top of the frame and made the original top hole the new bottom and drilled a new top hole in the angle iron, piece of cake and an easy fix.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
