Is there a way to convert to serpentine?
Topic: Is there a way to convert to serpentine? (Read 6852 times)
Skunksmash
September 08, 2008, 04:21:55 pm »
I would like to convert my 87 Silverado 5.7L 2WD to a serpentine belt system instead of all those little belts. Anyone know the best way to go about this?
Re: Is there a way to convert to serpentine?
September 08, 2008, 05:36:47 pm »
Junkyard or you can actually buy the whole kit from GM.
camdenoilchange
September 08, 2008, 05:47:30 pm »
junkyard and a little elbow grease will be the cheapest route. I've been looking around and the after market kits are $$$$$$!
Skunksmash
September 08, 2008, 06:32:49 pm »
Thanks guys, anyone got a link? Also, for the junkyard way: What year of truck do i need to look for, and what all parts are involved?
September 08, 2008, 09:32:11 pm »
Serpentine started on the trucks in 1987 as an option, you could also get it off of F-bodies.
You can also get it off of the newer trucks (Vortec) with the better/smaller AC compressor...
Skunksmash
September 09, 2008, 01:19:55 am »
Interesting... whats better about that AC compressor?
September 09, 2008, 01:49:46 pm »
It works with 134A and it doesn't take much power to operate in my opinion.
Skunksmash
September 09, 2008, 07:02:04 pm »
Quote from: Captkaos on September 09, 2008, 01:49:46 pm
Well my truck has this sticker that says "This system has been retrofitted to use R134A refrigerant" so does that mean that i have to have the newer compressor, or does it mean that i could still have the old one?
September 09, 2008, 07:24:29 pm »
I believe he's referring to the V5 compressor which a variable displacement compressor. You probably have an R4 compressor.
V5
R4
⌠ŻŻŻŻŻ' [☼===☼]
September 09, 2008, 09:37:17 pm »
Correct. R4 came on our trucks, the V5 came on the later Vortecs.
Skunksmash
September 09, 2008, 11:35:31 pm »
Dang. Well i guess this could all just be part of the conversion process then. I guess you have to have that newer compressor to make the conversion work?
September 10, 2008, 08:15:39 am »
Not if you have the bracketry for the R4
⌠ŻŻŻŻŻ' [☼===☼]
September 10, 2008, 01:11:02 pm »
There are basically 2 Truck serp setups, whichever you get will dictate what compressor you get...
