Author Topic: how to remove parking brake  (Read 10098 times)
Offline hotrod24
« on: September 13, 2008, 09:31:35 pm »
hey i am trying to get my parking brake out but i can not get the cable out of the slot is there a way of doing this? i have it unbolted so i just need to get the cable free from it i have a haynes manual and it said to just slip the cable with the ball through the slot but it is not that easy.
« Last Edit: September 14, 2008, 10:34:09 pm by hotrod24 »
1978 pontiac grand prix...
Re: how to remove parking brake
« Reply #1 on: September 13, 2008, 11:43:16 pm »
But it is that easy. Loosen the slack on the equalizer and unhook it. If it has a connector with locking tabs pry up the locking tabs first.
Offline hotrod24
« Reply #2 on: September 14, 2008, 10:33:29 pm »
 which equalizer is it the front one and the locking tabs are on the cable right?
« Last Edit: September 14, 2008, 10:57:44 pm by hotrod24 »
Offline SUX2BU99
« Reply #3 on: September 16, 2008, 04:51:08 pm »
I had this exact problem when I took my e-brake out, and I posted it on here. That was early 2005 I'd say. I didn't mess with the equalizer, but I did have to fight with it. I believe I was able to grasp it with some needle nose pliers or somsething like that and pull on it until I was able to slip the ball out of the holder it sits in. You are fighting though against spring pressure back in the rear drums.
Offline hotrod24
« Reply #4 on: September 16, 2008, 09:01:06 pm »
i tryed that with some pliers but it would not budge but i will try it again when the rain stops :)
Offline hotrod24
« Reply #5 on: September 18, 2008, 06:21:04 pm »
ok i got the parking brake out but i had to cut the the cable because the nut on the equalizer would not come off but i did get it out lol
