Author Topic: Pontiac vs chevy 350.....any differences?  (Read 21038 times)
Offline txtj79
  • 1980 Chevy C-10 SWB
« on: September 14, 2008, 08:14:13 pm »
I have a chance to buy a good 350 longblock out of a '71 Firebird.  I plan on putting it in a '78 C-10.  Is there any difference between the block and a chevy block?
Thanks,
T.J.
Offline 86 chevy silverado
Re: Pontiac vs chevy 350.....any differences?
« Reply #1 on: September 14, 2008, 08:31:40 pm »
Completely different if it is a pontiac 350. Are you asking if it will bolt in?
« Reply #2 on: September 14, 2008, 08:55:47 pm »
Offline HAULIN IT
« Reply #3 on: September 14, 2008, 09:05:21 pm »
TJ, Beyond the numbers 3 5 0, they have little to nothing in common (assuming the Firebird still has a Pontiac engine in it). Lorne
Offline txtj79
« Reply #4 on: September 14, 2008, 09:28:30 pm »
ok, that's what I needed to know.
Thanks,
T.J.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #5 on: September 14, 2008, 11:28:58 pm »
dont rule out the fact that the firebird is now 37 years old and could very well have a 350 chevy swapped in.
Offline SUX2BU99
« Reply #6 on: September 15, 2008, 09:47:24 am »
The nice part is if you do the Poncho swap, trading up to a 455 later on is a simple bolt in, since they are identical motors. Buick, Pontiac and Olds were interesting that way: they all used 1-size block for small to large displacement.
Offline jollyroger040
« Reply #7 on: September 15, 2008, 02:17:39 pm »
Only the Pontiac was like that. Buick and Olds had short and tall deck engines.
Offline Stewart G Griffin
« Reply #8 on: September 16, 2008, 11:33:08 am »
The other difference is that the bellhousing pattern is different from chevy's;  So you'll have to get an adapter plate or get a different patterned transmission;  Buick, olds, and pontiac(also cadillac) have a certain transmission bellhousing pattern----so here's where the term, B.O.P. came about.  Chevy and cadillac share the other pattern.  Why GM did this, i have no idea.
Another thing is that the frame mounts may have to be changed or the brackets that attach to the engine may have to be changed in order to install it in the truck's chassis.  i will attempt to do some research on this if i get the time.
Pontiac v-8's (from what i've heard?)tend to have more lower end torque while chevys dominate middle and top end? (i think?)
By the way, i love all GM engines even cadillac's.
i love them in this order:
1 chevy
2 pontiac
3 gmc
4 detroit diesel
5 olds
6 buick
7 cadillac
i think a possible advantage to pontiac engines is that since no-one wants them, you can get them for cheap or next to nothing or possibly free.
Here is an excellent video clip for anyone into pontiac/pontiac engines:
http://jp.youtube.com/watch?v=hg4QtYizPKM
i would say definitely go for it.
NOTE: 9/17/08 mr. Lorne corrected me on the BOP trans pattern---cadillac also shares it.
« Last Edit: September 17, 2008, 01:17:48 pm by Stewart G Griffin »
Offline SUX2BU99
« Reply #9 on: September 16, 2008, 12:48:46 pm »
A couple of guys on here (Lorne aka Haulinit and Uno99) both use Olds motors. Lorne has a 455 Olds that puts his truck into the mid-12s. He told me how he did the mating of the motor to the stock Chevy mounts and it doesn't seem that complicated.
Offline HAULIN IT
« Reply #10 on: September 16, 2008, 07:14:10 pm »
Stew, The Caddy's are the same bell housing as the BOP, Chevy is all by itself. Just want to keep everybody on the right page. Lorne
Offline SUX2BU99
« Reply #11 on: September 17, 2008, 11:47:22 am »
Further to that, that only applies to the 472 and 500 motors. The 429 and down had their own thing going on. The 66 Caddy hearse I have has a 429 with a TH400 "Switch-Pitch" tranny that basicaly has no more reverse and I think has given up on 2nd and 3rd gear. Replacing with it with anything but the same was not possible, so only a rebuild can be done and that's apparently going to be $1000 :(
« Reply #12 on: September 17, 2008, 01:08:16 pm »
Bah, you can rebuild that sucker for about $200 bucks. If it is a switch pitch hold on to it provided no one ever replaced the torque converter.
« Reply #13 on: September 17, 2008, 01:16:01 pm »
Yes, you're right.  i must have mis-read or something?  Maybe chevy and cadillac share the same internal gearings or something?  i know they share something that BOP doesn't.
Offline SUX2BU99
« Reply #14 on: September 17, 2008, 01:20:58 pm »
Yeah, typical quote from the tranny shops around here that just like to soak people for everything they got.  I think that's an interesting idea with the whole switch pitch thing. Kinda like a high and low stall converter built into 1 eh? Must not have worked well or who knows since they didn't offer it very long.
