Author Topic: removing harmonic balancer off a 350  (Read 11647 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: September 19, 2008, 02:48:15 pm »
I can't get it off my 350. Yes I made sure there isnt a washer in there. So far I broke 2 rented pullers from autozone, and 1 crafstman ratchet. I used some pb blaster. I used a big sledge hammer. I have not used heat though. Any suggestions other than cutting it off?
Re: removing harmonic balancer off a 350
« Reply #1 on: September 19, 2008, 02:57:47 pm »
What are you pressing off of? You removed the center bolt and the pulley and are threading the puller into the balancer and pressing off of a smaller bolt in the center of the crank to avoid damaging the threads right?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: September 19, 2008, 03:03:25 pm »
yes Im doing it exactly as you described. done it many times over the years on many small block chevy motors. This is the first one that I have come across that has been stuck.
Offline 80stepsideguy
« Reply #3 on: September 19, 2008, 03:13:45 pm »
Try some penetrating oil like PB blaster, let it sit for a few and then try it again, if that doesnt work try some heat from like a torch and it sohuld come loose after that.
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #4 on: September 19, 2008, 05:00:20 pm »
Yeah heat it but remember to replace your front oil seal.
Offline Blue 82
« Reply #5 on: September 20, 2008, 03:12:06 pm »
Kroil works better than PB Blaster for me
Soak it Kroil for an hour
you are really not in a hurry at this point
Use an impact wrench
the vibration really helps
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #6 on: September 20, 2008, 03:17:13 pm »
ok, 3 balancer pullers later, all with stripped threads. autozone exchanged everyone of them for free. 2 crafstman ratchets later. sears gladly exchanged those too. Some heat and a 5 lb sledge later its finally off  ::)
Offline Blue 82
« Reply #7 on: September 20, 2008, 03:23:04 pm »
see if you can find a ZZ4 balancer
I used to get new take-off for $35 on Ebay
