Author Topic: turn signal indicators  (Read 8972 times)
Offline Thermal Izod
« on: September 24, 2008, 12:22:20 am »
what r the turn signal indicators on the dash?  light bulbs?  I ask b/c one of mine stopped lighting, though the signal is still on.....
82 K10
1982 Shortbed K10 Silverado.  305 ci with a mild cam, full true dual exhaust (Long tube headers, "H" pipe, and Thrush Turbo mufflers.  4x4, and otherwise completely stock.  about 153,000 miles.
Offline Dragon
Re: turn signal indicators
« Reply #1 on: September 24, 2008, 03:28:33 am »
Should be a 168, and can be a pain to remove from the back of the cluster, if it has never been changed before.....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
« Reply #2 on: September 24, 2008, 09:03:21 am »
thanks dragon
« Reply #3 on: September 24, 2008, 10:24:45 am »
Depending on where it is located and how big or small your arm is, you may need to remove the cluster to replace them.  If you do, I would replace all of them while you had it out.  It is not easy to twist them in except for maybe the lower ones.
Offline ccz145a
« Reply #4 on: September 24, 2008, 10:36:10 am »
Oh, and test the new bulbs BEFORE you put them in. Ask me how I know ;)
Offline JJSZABO
« Reply #5 on: September 24, 2008, 11:16:32 am »
 :D :D  I am glad I am not the only one
Jeff
86 Chevy C-10
350, TH400
Offline Dragon
« Reply #6 on: September 24, 2008, 01:03:34 pm »
Sometimes you can get a different position on te bulb, or even the bulb mounting base that won't work one way, but you can rotate either 180, and it will work fine......  I know my Old '89 K2500,Dad's '76 C20,My '86 & '87 Buicks,'79 Monte, and '96 Caprice were all picky when it came to the dash lights.....
Dragon
08 Magnum-New Toy
Offline Skunksmash
« Reply #7 on: September 25, 2008, 03:21:55 am »
Yes it is in fact a light bulb. I replaced mine one time cause it went out just like yours did. Do not lose the little green piece of plastic that goes in front of the bulb or you will be going to the junk yard for a new one. I forgot to put mine back on and it was blinding light coming out of there without it. I also put LED lights in there one time and that was also way to bright.
