Heater core/repair manual
Topic: Heater core/repair manual (Read 5864 times)
lawdog49
September 29, 2008, 08:09:48 pm »
2 questions-
How difficult to change heater core in 91 Burb?
Which is the best repair manual to buy- Haynes, Chilton, etc.?
1991 GMC Suburban 1500 - 5.7/AT/4x4/TBI
Re: Heater core/repair manual
September 29, 2008, 08:10:43 pm »
The best manual is the factory service manual. Does it have AC?
lawdog49
September 29, 2008, 08:46:15 pm »
yep, it does have AC. bought the truck and they had just t-ed off the lines, apparently the core was leaking/bad.
September 29, 2008, 09:01:27 pm »
It isn't fun, you practiacally have to remove the AC system to get to it.
ccz145a
September 29, 2008, 11:00:31 pm »
And those bottom nuts on the air handler are a bugger with the inner fenders in the way
September 30, 2008, 12:05:16 pm »
You can do it without dropping the inner fender if you have swivel 1/4" drive sockets.
1988-91 R/V Series WITH AIR CONDITIONING
Disconnect the negative battery cable.
Disconnect the heater hoses at the core tubes and drain the engine coolant. Plug the core tubes to prevent spillage.
Remove the glove compartment and door.
Disconnect the center duct from the defroster outlet duct.
Disconnect the center, lower air distributor and the center air outlet ducts.
Disconnect the temperature door cable.
Remove the nuts from the 3 selector duct studs that project into the engine compartment.
Remove the outlet duct-to-instrument panel screws. Pull the assembly rearward to gain access to the wiring harness and disconnect the wires and vacuum tubes attached to the unit.
Remove the heater distributor from the truck.
Remove the heater core retaining straps and remove the core from the case.
To install:
Install the heater core. Be sure that the core-to-core and case-to-dash panel sealer is intact.
Position the heater distributor. Connect the wires attached to it and then install the heater distributor-to-instrument panel screws.
Install the floor outlet and tighten the defroster duct-to-heater distributor screw.
Connect the temperature door cable.
Connect the center and lower air distributors and the center air outlet ducts.
Connect the center duct to the defroster outlet duct.
Install the glove compartment and door.
Connect the heater hoses at the core tubes.
Connect the negative battery cable. Fill the cooling system and check for leaks.
lawdog49
September 30, 2008, 01:48:42 pm »
thanks guys, sounds like i may wanna farm this one out to my buddy to do......
ccz145a
September 30, 2008, 04:26:37 pm »
Don't do it. It's really not that hard, especially compared to some of these newer cars/trucks.
September 30, 2008, 04:45:38 pm »
Unless he is doing it for free I would do it myself. It isn't difficult as say a S10, which is a major undertaking. You can do it.
