Author Topic: 14 bolt questions  (Read 13363 times)
Offline lawdog49
14 bolt questions
« on: October 05, 2008, 07:59:30 pm »
Hey guys, found a 1982 C20, 2wd, manual trans 6.2 diesel truck.  I was looking at the rearend, appears to be the 14 bolt with 10.5 " gear, any ideas what gear ration it might've been on this truck?  Wondering if I should try to snag it for future transplant into the Burb, as I have the standard 1/2 ton 10 bolt.  I figure it is a bit wider than the Burb rear.  Not sure what it would be worth, but I think I can get whatever parts I wanted from the truck- which is basically just the mentioned drivetrain parts and a well used up/rusted partial body.  Interior mostly gone, couldn't find any codes to reference...
1991 GMC Suburban 1500   -   5.7/AT/4x4/TBI
Re: 14 bolt questions
« Reply #1 on: October 05, 2008, 08:37:46 pm »
It will most like be a semi floating rear (no hubs).  The are normally geared relatively high and some had 4.10's.  It is a bonus if you plan to do a lot of towing, but otherwise the 10 bolt would be fine.
« Reply #2 on: October 05, 2008, 10:11:02 pm »
Dito on what Chris said. Also it is the same width as the ten bolt.
Offline lawdog49
« Reply #3 on: October 06, 2008, 08:32:53 am »
How do you look at it and tell semi/full floating?  excuse my ignorance here ???
« Reply #4 on: October 06, 2008, 10:36:47 am »
A full floating axle supports none of the weight of the vehicle. It's bolted in on these axles and is nothing more than a connection between the differentil side gears and the driving hubs your wheels are bolted to.
A semi floating axle supports the weight of the vehicle on the axle with bearings.
« Reply #5 on: October 06, 2008, 11:56:04 am »
on a full float, it will have a hub like a 4x4 with no lock/unlock tab.  It will protrude from the wheel center about 6"
a semi-float will look just like your 10bolt, everything will be flush with the back of the rim.
Offline lawdog49
« Reply #6 on: October 06, 2008, 01:45:51 pm »
ok, so this must be a full floater- cause it had a hub sticking out with several bolts appearing to attach it .  might be worth snagging, even for a resale to someone that needed the HD capability..
« Reply #7 on: October 06, 2008, 02:11:19 pm »
Does the truck run?  If you can get it cheap it wouldn't be too bad a deal.
« Reply #8 on: October 06, 2008, 05:17:50 pm »
I sold a full float out of a 1985 Suburban for $300.  You might luck out and see the ratio stated on the sticker on the glove box.  If it has the sticker on the door still you can look up the code, this is assuming it has not been changed.
