Author Topic: transmission fluid leak  (Read 12970 times)
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« on: October 06, 2008, 04:41:10 pm »
I got one for you master mechanics.
I walked around my 79 Big 10 today.  I haven't driven it for a few days and I noticed a puddle of tranny fluid coming from under the truck.
So i crawled up under it and at first thought it was the donut-type seal for the slip yoke.  But, it was dry all around that seal.
I looked closer at the drips--it is still dripping as I type this, and it seems to come from the yoke itself..
Isn't there a hole that goes through the center of the yoke itself?  What could be wrong?  It drips directly from the u-joints....the yoke around the seal is dry so it couldn't be a bad seal there.
Re: transmission fluid leak
« Reply #1 on: October 06, 2008, 05:17:49 pm »
there is a bulletin on those leaks. I used to just plug them but I'll see if I can dig it up for you
« Reply #2 on: October 06, 2008, 05:18:28 pm »
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #3 on: October 06, 2008, 10:54:18 pm »
I don't remember that "cup" being there when I put my trans in the truck and slid the speedo gear on the tail shaft, maybe I just have alzheimer's, but I don't remember that being on my TH350c.
Vile, if you plug the weep hole, what do you plug it with?
thanks for the help, as always.
« Reply #4 on: October 07, 2008, 07:35:50 am »
Jb weld works fine or if you don't have any clean it out and put in some good RTV
Offline ccz145a
« Reply #5 on: October 07, 2008, 11:16:13 am »
I packed some white lithium grease back in there.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #6 on: October 07, 2008, 11:35:21 am »
Thanks.  As soon as I get back from the Outer Banks of NC, I'll drop the drive shaft and tail cone of tranny and investigate the o ring.  If I can't see that, I'll just plug the weep hole up.
thanks for the input.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #7 on: October 16, 2008, 05:24:09 pm »
Well, I removed the driveshaft today.  Removed the tranny extension housing and speedo cable.  Saw the cup with the O ring.  Went to the salvage yard and removed a cup from an existing th350 and put it on my trans.  So far, no problems.
