Author Topic: AC removal question  (Read 12125 times)
Offline baddogg79
AC removal question
« on: October 12, 2008, 07:21:11 pm »
On my 73, it came with factory AC. Im not going to use it, so its long gone. Now that Im in the reassembly phase, I want to put all the right non-ac parts in the cab ( fresh air vents, controls, etc) My question is, for the controls, do I need to get all the rods and levers from a non-ac truck? Or I can just get the controls and use the rest of the existing pieces?  I know I need the controls itself.  The vents are pretty much straight forward. I hope this makes some sense ??? :P
Re: AC removal question
« Reply #1 on: October 12, 2008, 07:27:14 pm »
Just leave everything in tact. Remove tha AC components in the engine compartment. You can also put in one of these http://www.acdelete.com/pages/73-90_Truck.htm
Offline baddogg79
« Reply #2 on: October 12, 2008, 07:29:43 pm »
cool, I already got one of those delete plates 8) makes me feel better that I dont have to get all the parts from a non ac truck ;D
« Reply #3 on: October 13, 2008, 07:54:42 am »
I actually pulled the harness back through the firewall and hid it all under the dash. I cut a precision hole also in the inner evaporator case for the blower motor resistor so that was hidden too.
Offline 87GMC2WD
« Reply #4 on: November 24, 2008, 04:33:10 pm »
any cheaper delete parts? becuase im doing that to mine to and i dont think i want to spend 170 on it
Offline frogman68
« Reply #5 on: November 24, 2008, 04:39:04 pm »
You might be able to fab a piece to fit in there..
Offline 82ChebySWB
« Reply #6 on: November 26, 2008, 09:56:49 pm »
Don't worry, I'm in the same boat as you. I'm removing all of the ac components and going with just a heater/defrost system.......but I just can't justify spending $170 for a cover alone.  I'll eventually find an ac delete truck locally to pull the cover from.
Brian
'82 Chevy Silverado AKA Project "Cheby"
Offline 87GMC2WD
« Reply #7 on: November 26, 2008, 10:16:01 pm »
you know that sounds best to me too
« Reply #8 on: November 27, 2008, 10:23:01 am »
I lucked out and have two cabs w/ the factory delete. That is about the only thing left on them that is good though
