Author Topic: Maximizing quench  (Read 5552 times)
Offline eventhorizon66
Maximizing quench
« on: October 13, 2008, 07:26:41 pm »
Another crazy idea.  If I were to pull my heads, say...to change out valve springs, could I reinstall them with a gasket like this and expect them to seal indefinitely on a street engine?  I realize this type gasket is less tolerant to warpage in the heads or block than a thicker composition type, but what amount of warpage should I consider too much for them?
'85 C10 SWB 350 700R4 TKO600
Re: Maximizing quench
« Reply #1 on: October 13, 2008, 07:48:05 pm »
I wouldn't for longevity of a street truck.
« Reply #2 on: October 13, 2008, 07:55:31 pm »
That's what I thought.  I guess I'll just wait until I rebuild the engine for performance and zero deck the block at that time.
Offline Blue 82
« Reply #3 on: October 13, 2008, 08:03:49 pm »
GM used steel shim gaskets for years on SBC trucks
I would imagine anything greater than .002" would be of concern.
When torqueing your heads on using a 3 step torque incrediment sequence
I find that torqueing both heads evenly adds to longevity
(maybe it's just wishful thinking)
I like this method,
torque both heads to step one (say 20 ft/lb for example)
then torque both to step #2  (say, 40 or 45 ft/lbs)
then finish em up
vs
torqueing one head all the way tight with 3 steps
then doing the other head with 3 steps
Offline joesgarage71
  • Wrench
« Reply #4 on: October 19, 2008, 12:42:27 pm »
 I use steel shim head gaskets all the time but never have used ones with rubber coating.
« Reply #5 on: October 19, 2008, 07:30:27 pm »
I have also heard of people successfully using copper shim gaskets in engines without o-rings.  The only concern I have with shims is, even if the decks are flat enough for a good seal today, 100,000 miles down the road they could be warped just enough to cause gasket failure.
