Author Topic: slightly lowered SWB - shock help  (Read 15863 times)
Offline vince311
« on: October 16, 2008, 02:00:23 pm »
Rookie question...so bare with me.
My 82 SWB seems to be lowered a bit....but I'm not really sure of a couple things. 1) how it was lowered and 2) how much it was lowered.
Much like other posts, I'm looking to replace shocks....and want to know what I have before ordering. I have coil springs in front, leaf springs in back. All four shocks look to be fairly well worn and the ride is pretty rough. Based on the chart in the   mag...to me, it looks like its lowered 2" front and rear.
I can post pics if needed, just let me know what specifically needs to be identified or measured.
« Last Edit: October 16, 2008, 02:15:28 pm by vince311 »
'82 Chevy shortwide, 2wd, 350/350 - Sold
Re: slightly lowered SWB - shock help
« Reply #1 on: October 16, 2008, 03:00:03 pm »
Post a side shot of the truck.
« Reply #2 on: October 16, 2008, 05:02:06 pm »
If it's lowered only 2" you can run stock shocks.
Offline vince311
« Reply #3 on: October 16, 2008, 05:04:30 pm »
both front and rear?
« Reply #4 on: October 16, 2008, 05:08:04 pm »
yeah
Offline eventhorizon66
« Reply #5 on: October 16, 2008, 06:04:33 pm »
For the front, lower springs will affect installed shock length, but not lowering spindles.
'85 C10 SWB 350 700R4 TKO600
Offline vince311
« Reply #6 on: October 16, 2008, 06:06:33 pm »
this is what some of other posts seem to indicate. From what I gather, 2" front drop may benefit from drop shocks...but 2" rear drop can still use regular shocks.
Anyone have issues with the Monroe Sensatrac shocks? good/bad?
Offline ms4972
« Reply #7 on: October 16, 2008, 11:40:54 pm »
Measure the distance between the shock mounts at ride hieght and you will take all of the guesswork out of choosing the correct shocks.
Offline vince311
« Reply #8 on: October 18, 2008, 01:51:57 pm »
here's a pic of the side. the front fender is measuring 31" and the rear is 32"
« Reply #9 on: October 18, 2008, 09:21:19 pm »
It doesn't even look lowered. what size tires do you have? You can run stock shocks.
Offline vince311
« Reply #10 on: October 18, 2008, 09:46:25 pm »
235/60/15
« Reply #11 on: October 18, 2008, 10:12:06 pm »
Your truck isn't lowered.
This is my 87R10 completely stock:
Offline vince311
« Reply #12 on: October 18, 2008, 10:41:51 pm »
interesting. ok then...that helps. for some reason it just feels a bit lower than other 2wd trucks i've been in. that and the ride is so rough, i just figured it had been lowered a couple inches. thanks guys for setting me straight.
« Reply #13 on: October 18, 2008, 10:48:46 pm »
It may not be lowered but it sure looks clean.  Nice truck.
I've heard over and over that the reason these trucks ride so rough relative to other trucks is inadequate shocks.  The actual reason is the high unsprung to sprung weight ratio.  The more the moving suspension components, brakes, wheels, and tires weigh relative to everything else (body, frame, drivetrain), the worse the ride quality will become.  This is why a big block truck almost always rides nicer than a small block, even with slightly stiffer springs.  A high quality shock that can better control the unsprung weight would conceivably improve ride quality.
« Reply #14 on: October 18, 2008, 11:12:14 pm »
The Short wheelbase trucks rides rougher also.
