Author Topic: Explain this to me please  (Read 4305 times)
Offline Ill Named
« on: October 21, 2008, 07:00:54 pm »
The fuel gauge in my 78 3/4 has not worked since I have owned the truck. So today I decided to try to do something about it. I figured that it might be the gauge itself because nothing happens when I flip the tank switch, so I popped open the cluster and replaced it along with a few lights and the clear plastic. That was not the problem. I did some snooping around under the dash and found that the previous owner had cut the blue wire coming from the selector switch and fed it into an aftermarket autometer fuel gauge that also doesn't work. So I re-hooked that wire together and still nothing. When I installed the other gauge I set it to E and when I turned the ignition switch the it shot up to way past full. I understand that this indicates a bad sender but it does nothing different at all when I flip the tank switch, and I know that that works. I suppose that both senders could be bad.
How does the gauge know what tank to read? Is there a switch motor somewhere for that that I have not come across? I kind of thought that it would be fed through the tank switch itself, but all of the wires coming from that run outside the cab except the pink/black that just goes to the fuse block. So how do the senders reach the gauge?
Thanks
Ill
Re: Explain this to me please
« Reply #1 on: October 22, 2008, 03:24:04 pm »
I've posted the answer to this with schematics and the diagnostic flow chart several times. Maybe Chris can post it in technical pages.
« Reply #2 on: October 22, 2008, 04:10:37 pm »
Did I not?  I will look for it and move it if I can.  Your right, this comes up OFTEN.
BTW you can also do a search on the board.
« Reply #4 on: October 22, 2008, 07:27:29 pm »
Done.
Offline Ill Named
« Reply #5 on: October 23, 2008, 06:23:13 am »
Thank you for the link and I did you a search. That schematic linked is not the same as the one in my truck. My valve only has one wire going to it and those wire color designations are way out to lunch in comparison to mine. I think that that one was for an 87 I believe the post said, that can't be the same as a 78 can it?
« Reply #6 on: October 23, 2008, 10:11:59 am »
The wire goes into the fuse box and goes to the cluster wiring.  This is how it gets the feed.
