Author Topic: Anyone use this cam before?  (Read 4493 times)
Offline 84shortbed
« on: October 27, 2008, 11:31:12 am »
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=95&sb=2
It will go in a 9.2:1 355 with mild ported 882 heads with 2.02/1.6 valves. The 84 stepside I picked up has a stock 305 that can`t get out of it`s own way. The truck has a 700R4 and unknown gear ratio but seems like 3.08`s. Anyone use this cam? Does anyone know if it will be smog legal in CA? The notes say it is 50 state but I don`t know for sure. Thanks.
Anthony
83 chevy short fleetside
OTR gearjammer
Re: Anyone use this cam before?
« Reply #1 on: October 27, 2008, 03:48:30 pm »
That's a pretty mild cam and you should have no problems with CA emissions if you are well tuned, running cats and EGR
Offline 84shortbed
« Reply #2 on: October 28, 2008, 11:50:38 pm »
yeah I plan to run all the ca smog stuff. This is only the 2nd truck engine I`ve built so it`s hard for me to be so mild on the cam but this one looked like it would give some good performance.
Anthony
OTR gearjammer
