Author Topic: shaved door wiring and backup buttons  (Read 15628 times)
Offline nucknoel89
  • Proud to be Canadian!
« on: October 27, 2008, 02:06:14 pm »
A few questions about the electrical side of shaved doors.  I already have the solenoids and cable installed, and I've got a fair bit of the wiring put together.  However, I'm still wondering, where do I plug the positive ends in so I get a constant power source?  I see the accesory slots on the fuse panel but I'm pretty sure they only work when the key is turned.  Also, what about the emergency switch?  How do I fit that in to the circuit?
Online Captkaos
Re: shaved door wiring and backup buttons
« Reply #1 on: October 27, 2008, 02:19:19 pm »
You need a 12V source not a switched source.  For example if you have a clock or a radio with clock it will have constant power.  There is a power slot on the fuse ciruit though.
Offline nucknoel89
« Reply #2 on: October 27, 2008, 02:28:15 pm »
Do you have a picture?
Online Captkaos
« Reply #3 on: October 27, 2008, 02:31:08 pm »
Picture of?
Offline nucknoel89
« Reply #4 on: October 27, 2008, 02:37:32 pm »
Picture of?
Oops, sorry, picture of the power slot on the fuse circuit, or can you describe where approximately it is?
« Reply #5 on: October 27, 2008, 03:41:55 pm »
It says BAT and is constant power already circuit protected.
Offline nucknoel89
« Reply #6 on: October 27, 2008, 03:46:34 pm »
Ah sweet, I was saw that but wasn't sure, thanks!  Now anyone know about the backup buttons?
« Reply #7 on: October 27, 2008, 03:49:39 pm »
What kit do you have? Didn't it come with diagrams or instructions? I just leave one vent window unlocked in case the poppers don't work.
Offline nucknoel89
« Reply #8 on: October 27, 2008, 05:23:35 pm »
The kit I got came from the seller hotrodaccessory on eBay.  The auction link no longer works and the ones he's selling now aren't exactly the same, and it did have instructions, but I didn't see anything that showed me where the backup switches fit into the circuit.  And I still have the handles and locks on for now.  I'm not removing anything till I'm sure it all works :)
Also, another question.  I plugged into the BAT slot, pressed the button on the remote, and I heard the solenoid activate!  Unfortunatley, it just worked the one time, after that nothing happened when I pushed the button.  Is there some fuse I could have blown?  There is a seperate fuse on the wire from the fuse box to the reciever, but that fuse appears fine...
Online Captkaos
« Reply #9 on: October 27, 2008, 05:33:19 pm »
There should be a fuse inline with the switch.
As for backup, if the solenoid goes bad, you are out of luck, you won't be able to get into the truck.
If you are wanting a backup for a hard wired button, I don't see the point.  Now if you had remote solenoids and wanted a hard line backup I could see that.
Offline nucknoel89
« Reply #11 on: October 28, 2008, 12:00:05 am »
Offline nucknoel89
« Reply #12 on: October 28, 2008, 12:02:27 am »
All I know is the kit came with 2 little black and red buttons and I dunno what else they're for.
EDIT: Found the problem fuse.  It controls at least the horn, the dome light, and the "BAT" slot.  Removed the popped 20 fuse and put in a 25 and it seems to work for now...
« Last Edit: October 28, 2008, 12:49:36 am by nucknoel89 »
