Author Topic: New Guy from Southwest Virginia  (Read 14386 times)
Offline Hooligan
« on: October 28, 2008, 06:54:06 pm »
Just traded my '79 Pontiac T/A for a 1980 GMC C-10.  This truck has tons of potential.  Not saying the T/A didn't, but the parts for my C-10 are 1/2 the price of what the parts for my T/A were.  First to go is the black grill and the bald tires.  I'm probably going with a set of 255/60 BFG Radials until I replace the wheels and I'm putting a stock chrome/silver complete grill back in it.  I hope to learn alot from this forum and hopefully give some good advice also.
IF ONLY THOSE WHO KNEW IT ALL COULD DO IT ALL.
1980 GMC C-10 SWB 2wd
2008 Pontiac G8 GT
1988 Ford F-150 4x4
1940 Chevrolet Buisness Coupe
Offline hotrod24
Re: New Guy from Southwest Virginia
« Reply #1 on: October 28, 2008, 07:01:49 pm »
nice looking truck i would get rid of them 80 head light covers and put in some round 73-78 to go with that grille nice man very nice
1978 pontiac grand prix...
Offline Hooligan
« Reply #2 on: October 28, 2008, 07:40:08 pm »
Thanks man.  It has round headlights now but what year grills would I be able to bolt right up without having to change the hood latch or anything else?  I've tried to find out on my own with GOOGLE, the search button, etc. but haven't really found a spot on answer.  Here is a pic of the front of the truck and yes the "hood ornament" is coming off asap also.
2008 Pontiac G8 GT
1988 Ford F-150 4x4
Offline hotrod24
« Reply #3 on: October 28, 2008, 08:05:45 pm »
well from seeing the front a little better now it looks nice but i what year grille are you wanting to use?
Offline Hooligan
« Reply #4 on: October 28, 2008, 08:12:53 pm »
I'm thinking maybe a '77 Chevrolet grill and headlight bezels.  I don't really like how the headlight bezels on the '79-'80 trucks surround the marker light also.  Thats really the biggest thing that bothers me about this grill, other than it having a very poor rattle can black paint job.  I'd love to run a complete '73 grill, but don't want to go through changing alot of stuff if its costly or a pain in the rear.
2008 Pontiac G8 GT
1988 Ford F-150 4x4
Offline hotrod24
« Reply #5 on: October 28, 2008, 08:27:09 pm »
well with a little silver paint you could have that 80 grille looking good and get some single head light covers i dont blame you on that one but for the 73 and 77 grille there would be a little work here is a link to help you out
http://www.4wheeloffroad.com/techarticles/1973_1980_chevy_square_front_clip_grille_swap/index.html
http://www.classicparts.com/1973-78-Headlamp-Bezel-Left/productinfo/48-031/
« Last Edit: October 28, 2008, 08:30:48 pm by hotrod24 »
Offline Hooligan
« Reply #6 on: October 28, 2008, 08:36:16 pm »
Thanks for the links.  Thats the cheapest I've seen the headlight bezels for new.  I may try to paint that grill silver, but it has an awful lot of black paint on it.  Then again I may just leave it black and replace all of the trim around it.  But heck what do I have to lose.  If I screw it up I'll just go ahead and get a new one then.  Thanks again for all the help.
2008 Pontiac G8 GT
1988 Ford F-150 4x4
Offline hotrod24
« Reply #7 on: October 28, 2008, 08:38:56 pm »
any time good luck
« Reply #8 on: October 28, 2008, 11:19:04 pm »
73-74 grilles require a specific hood latch and brace system along with grill supports.  Otherwise 75-78's are a bolt in.
Those bezels are plastic AFAIK.  No one remans pot metal bezels.
Offline Hooligan
« Reply #9 on: October 29, 2008, 01:24:29 pm »
Cool, Thanks for the info guys.
2008 Pontiac G8 GT
1988 Ford F-150 4x4
Offline ccz145a
« Reply #10 on: October 29, 2008, 01:41:57 pm »
Quote
75-76's have an offset release handle specific to those years.
Offline Hooligan
« Reply #11 on: October 29, 2008, 01:56:54 pm »
Quote
But '77-'80 C-10s have the release handle in the same position?
2008 Pontiac G8 GT
1988 Ford F-150 4x4
Offline hotrod24
« Reply #12 on: October 29, 2008, 02:15:37 pm »
yea my 78 has it but i think some had the inside hood release some outside
« Reply #13 on: October 29, 2008, 03:14:21 pm »
77-80 hood latch assemblies are the same.
For anything other than a 73-74 and 81-87. you need the center support/latch assembly, outer triangular brackets near the headlights. You will have to remove the vertical mid grill mounts because they will not work with the 73/74 grill.  On 73/74 core supports have them built into the support, 75-77 models they are bolted in. This will be OK, as you still have the center and outer grill supported. You will also need to drill the 3/8" holes for the outer brackets, but they are located with center punches from the factory. The outer brackets will need to be mounted with nuts and bolts, as there are no welded nuts in this area on the backside to bolt them in to.
« Last Edit: April 29, 2009, 08:37:21 pm by Captkaos »
« Reply #14 on: October 29, 2008, 03:22:10 pm »
BTW, Interior Hood release latch was an option starting in 1977.
