Author Topic: How to service front driveshaft U-joints?  (Read 8004 times)
Offline CruzinHigh
  • Chevy 4 life
« on: November 02, 2008, 01:25:57 pm »
The front one that joins to the diff seems easy enough.   But what about those back ones that mate up to the transfer case?  I guess they're ok, but I assume they're the originals and I'd like to get new ones just for safety sake since I am going through the entire driveline.
I should also add that this is an NP 208C
Also, do you need to index the front properly?  I forgot to mark it before taking apart on the front, DOOH!!  :-\
« Last Edit: November 02, 2008, 07:38:47 pm by CruzinHigh »
Mike Carter
1986 Chevy K-10 4x4
Offline 76 k10
Re: How to service front driveshaft U-joints?
« Reply #1 on: November 02, 2008, 08:56:32 pm »
your gonna have fun getting those out lol
Offline joesgarage71
  • Wrench
« Reply #2 on: November 03, 2008, 05:51:41 am »
 I'd take it to a driveshaft shop and have them replaced. Those are alittle harder but not impossiable see they have hot plastic shot into them to hold the caps in place, heat/press to get them apart, the new joints have clips to install. Mark with a punch before starting(index)
Steve
Offline CruzinHigh
  • Chevy 4 life
« Reply #3 on: November 03, 2008, 08:20:48 pm »
Thanks Joe.
Think I'll price the job locally but I do have a U-joint / Balljoint tool so I might give it a shot.  The trusty acetylene torch might be helpful too!   ;D
Mike Carter
1986 Chevy K-10 4x4
« Reply #4 on: November 03, 2008, 08:23:20 pm »
yes heat around the perimeter will force the plastic out. Make sure you have safety glasses on. They're just like any other u-joint however there is a cv inside the cardan joint. If that's shot now is the time to replace it also.
Offline dunedigger
« Reply #5 on: November 03, 2008, 08:30:18 pm »
I've always gotten out of that one, I have had my front shafts lengthened in my trucks when lifted and had them go through the whole thing at that time.  They don't look too fun.
Offline CruzinHigh
  • Chevy 4 life
« Reply #6 on: November 05, 2008, 07:26:55 pm »
And that brings a good point too, I plan to lift this truck 8" in the next few years, but I don't suppose that will really effect the fact I need to pay attention to the joints and the cardan joint too.  Thanks for pointing that one out too Vile.  I was going to remove the boot there and inspect the guts but now for sure I will just plan a replacement.
Mike Carter
1986 Chevy K-10 4x4
